Home » Modeling » Ecore Tools » Convert Ecore to UML
Convert Ecore to UML [message #1705299] Thu, 13 August 2015 15:02 Go to next message
meta model is currently offline meta modelFriend
The question I think is in the Title. How can I convert an ecore model to UML diagram ? I have eclipse Mars.
If some one can explain for me the different step ?
Thank you.
Re: Convert Ecore to UML [message #1705305 is a reply to message #1705299] Thu, 13 August 2015 15:41 Go to previous messageGo to next message
Cedric Brun is currently offline Cedric BrunFriend
you can follow the instructions here : https://www.eclipse.org/ecoretools/doc/index.html starting from "Creating diagrams from an existing Ecore", that should allow you to have a Class diagram for your Ecore model.
http://cedric.brun.io news and articles on eclipse and eclipse modeling.
Re: Convert Ecore to UML [message #1724359 is a reply to message #1705305] Tue, 23 February 2016 11:03 Go to previous messageGo to next message
Michael Zach is currently offline Michael ZachFriend
Hi Cedric,
but is it possible to have multiple such models per project?
I am looking for a way to use MDA and have both the metamodel and the model as UML diagrams in the same project.
I always end up with the metamodel being fine UML, but then the instantiation of it the model, I can only fill with Ecore tools, which is a pitty.
Kind regards
Michael
I have been following these tutorials so far:
http://www.vogella.com/tutorials/EclipseEMF/article.html
http://redpanda.nl/index.php?p=tutorial9
http://www.peterfriese.de/getting-started-with-code-generation-with-xpand/
[Updated on: Tue, 23 February 2016 11:04]
Report message to a moderator
Re: Convert Ecore to UML [message #1732483 is a reply to message #1724359] Tue, 17 May 2016 15:08 Go to previous message
I'm not sure to 100% get what you are asking for but I'll try to answer anyway, so feel free to correct me if there is something I misunderstood.
It looks like you would like to edit the instances of your metamodel graphically . If so, you have to first define the visual aspects of those instances, you might want to use Sirius https://eclipse.org/sirius/
Sirius is the underlying technology which is used by EcoreTools so that you can display and edit Ecore models.
Previous Topic:Renaming and regeneration?
Next Topic:EClass information view
Current Time: Sat Oct 24 01:24:33 GMT 2020
Powered by FUDForum. Page generated in 0.01538 seconds
