Home » Eclipse Projects » Standard Widget Toolkit (SWT) » RCP 3.7 / SWT and Windows Data Execution Prevention(SWT and Windows Data Execution Prevention -> JVM termintates from time to time)
RCP 3.7 / SWT and Windows Data Execution Prevention [message #1705274] Thu, 13 August 2015 12:10 Go to next message
Heiko Nolte is currently offline Heiko NolteFriend
I'm working on an RCP 3.7/SWT application using Windows as operating system. Under MS Windows XP everything works fine. Under MS Windows Server 2008 I'm experiencing random system crashes on opening the file chooser dialog.
MS Windows Server 2008 has got a security policy that is called DEP (Data Execution Prevention). Basically the feature stops a process if it tries to access memory areas with asking the operating system for permission.
I'm wondering if the JVM crashes are related to the DEP policy. I have had a look at the Java implementation class of the file chooser dialog. There one can see that system memory is allocated using native calls.
Did anybody have similar problems? Is there a new RCP/SWT version that considers DEP on allocating memory?
Kind regards,
Heiko
Re: RCP 3.7 / SWT and Windows Data Execution Prevention [message #1705304 is a reply to message #1705274] Thu, 13 August 2015 15:29 Go to previous messageGo to next message
Brian de Alwis is currently offline Brian de AlwisFriend
There are no bugs in the Eclipse bug database about 'data execution prevention'. I did find a post from Dataloy Confluence that notes:
Symptom
Dataloy crashes randomly on Windows 7/Windows Server 2008, but especially during startup or when when opening DDT module. The error tends to happen in ieEmbed.exe or rtutils.dll, but it might be elsewhere.
Cause
If DEP (Data Execution Protection) in Windows is enabled, it will interfere with Java Garbage Collection if it starts during a call to native code. These calls typically happen when getting a network connection and when opening the browser module.
Resolution
Exclude java.exe, javaw.exe and javaws.exe from DEP.
  1. Click 'Start'
  2. Right-click on 'Computer' and select 'Properties'
  3. 'Select Advanced System settings'
  4. Under 'Performance', click the 'Settings..' button
  5. Select the 'Data Execution Prevention' tab
  6. Click 'Add..' and add the files java.exe, javaw.exe and javaws.exe one by one. They are located in the Java installation directory or sometimes in WINDOWS/System32.
Brian.
Re: RCP 3.7 / SWT and Windows Data Execution Prevention [message #1705353 is a reply to message #1705304] Fri, 14 August 2015 06:16 Go to previous messageGo to next message
Hello Brian,
thank you for adding the Dataloy Confluence quote. I'll exclude the Java runtime from DEP control and see
I this will have an effect. Interesting is the information that the crash might be due to a running garbage collection.
Kind regards,
Heiko
Re: RCP 3.7 / SWT and Windows Data Execution Prevention [message #1705396 is a reply to message #1705353] Fri, 14 August 2015 14:33 Go to previous messageGo to next message
It's GC when there is external memory allocated using JNI. I don't know the cause, but I'd speculate that it has something to do with JIT'd code.
icon7.gif  Re: RCP 3.7 / SWT and Windows Data Execution Prevention [message #1709594 is a reply to message #1705396] Tue, 29 September 2015 13:08 Go to previous message
just a brief update on the issue: Removing our RCP executable and javaw.exe file from Windows 2008 Server DEP (Data Execution Prevention) resolved the problem.
Thank's for your help Razz
Heiko
Previous Topic:Adding Multiple Images to ExpandItem
Next Topic:FocusLost event raised when entering a Text
Current Time: Mon Mar 08 03:45:47 GMT 2021
Powered by FUDForum. Page generated in 0.02121 seconds
