Home » Eclipse Projects » Sirius » Row selector for Tree diagram
Row selector for Tree diagram [message #1705161] Wed, 12 August 2015 14:02 Go to next message
Arseniy Isakov is currently offline Arseniy IsakovFriend
Member
Hello
I have created simple tree diagram. If I select any node in the tree color of label is get changed But I'd like to see real row selection : entire row change background color.
How I can configure that?
Arseniy Isakov
Re: Row selector for Tree diagram [message #1705168 is a reply to message #1705161] Wed, 12 August 2015 14:39 Go to previous messageGo to next message
Laurent Redor is currently offline Laurent RedorFriend
I think you talk about "Table representation".
In the screenshot "tableSample.png" (extract from tests of Sirius:
/org.eclipse.sirius.tests.junit/data/table/unit/refresh/tables.aird),
the entire selected row has a specific background color. There is
nothing specific to configure for that. This is the default behavior.
I am not sure to understand your problem...
Le 12/08/2015 16:02, Arseniy Isakov a écrit :
> Hello I have created simple tree diagram. If I select any node in the
> Thanks
> Arseniy Isakov
Laurent Redor - Obeo
Re: Row selector for Tree diagram [message #1705170 is a reply to message #1705168] Wed, 12 August 2015 15:10 Go to previous messageGo to next message
Member
Take a look at attachments
Arseniy Isakov
Re: Row selector for Tree diagram [message #1705176 is a reply to message #1705170] Wed, 12 August 2015 15:48 Go to previous messageGo to next message
Maxime Porhel is currently offline Maxime PorhelFriend
Hi Arseniy
> Thanks
> Arseniy Isakov
This seems to corresponds to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=460810 which has been
corrected on master and will be available for Sirius 3.1
Maxime - Obeo
Maxime Porhel - Obeo
Re: Row selector for Tree diagram [message #1705190 is a reply to message #1705176] Wed, 12 August 2015 16:58 Go to previous messageGo to next message
Member
Actually I am not getting any exceptions. My error log is clean. How can I investigate it deeper?
Arseniy Isakov
Re: Row selector for Tree diagram [message #1705233 is a reply to message #1705190] Thu, 13 August 2015 07:17 Go to previous message
Hi Arseniy,
The exception mentionned on the bugzilla used to occur on some key
pressed events (arrows) in the Tree editor. The code causing your
"blank" selection and the exception has been removed/corrected on master.
You might try a nightly build if you want to test the correction.
> Thanks
> Arseniy Isakov
Maxime - Obeo
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=460810
Previous Topic:[ANN] Sirius Training
Next Topic:How to load representations from .aird-file
Current Time: Sat Mar 06 17:36:34 GMT 2021
Powered by FUDForum. Page generated in 0.02351 seconds
