Home » Archived » Test and Performance Tools Platform (TPTP) » TestNG plugin not showing test results in testNG output view
TestNG plugin not showing test results in testNG output view [message #1705081] Tue, 11 August 2015 22:32 Go to next message
tyree giles is currently offline tyree gilesFriend
Has anyone else seen this problem? I've followed the instructions to install the TestNG plugin, and have done it a million times before on older versions of eclipse.
The plugin seems to be installed correctly as far as I can tell ('run-as' entries for testng appear in dropdowns/context menus, etc), and running testNG tests works fine. But I always get blank output in the output view no matter what...
Re: TestNG plugin not showing test results in testNG output view [message #1705909 is a reply to message #1705081] Thu, 20 August 2015 00:19 Go to previous message
Mike YY is currently offline Mike YYFriend
I have the same problem (Eclipse 4.5) but no solution.
Previous Topic:JUnit Help
Next Topic:Webinar (Sept 8): How to create Cross-Platform Automated GUI Tests for Java Apps
Current Time: Sat May 30 21:38:54 GMT 2020
Powered by FUDForum. Page generated in 0.01991 seconds
