Cannot run Media Application sample under e(fx)clipse 2.0 [message #1705079] |
Tue, 11 August 2015 22:08  |
When trying to run the Media Application sample project under e(fx)clipse 2.0, I get the error(s) shown below
(I did not make any changes to the sample project).
The sample (as well as my own E4 application) runs fine under e(fx)clipse 1.2 but I cannot get anything to run on v2.0.
thanks!
!SESSION 2015-08-11 23:51:12.757 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_51
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_AT
Framework arguments: -product media.product
Command-line arguments: -product media.product -data J:\workspaces\java\TreskySuite/../runtime-media.product -dev file:J:/workspaces/java/TreskySuite/.metadata/.plugins/org.eclipse.pde.core/media.product.product/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog
!ENTRY org.eclipse.equinox.ds 1 0 2015-08-11 23:51:15.328
!MESSAGE Could not bind a reference of component org.eclipse.fx.core.internal.JUtilLoggerFactory. The reference is: Reference[name = registerHandler, interface = java.util.logging.Handler, policy = dynamic, policy-option = greedy, cardinality = 0..n, target = null, bind = registerHandler, unbind = unregisterHandler, updated = null]
!ENTRY org.eclipse.equinox.ds 1 0 2015-08-11 23:51:15.858
!MESSAGE Could not bind a reference of component media.themes.default. The reference is: Reference[name = Stylesheet, interface = org.eclipse.fx.ui.services.theme.Stylesheet, policy = dynamic, cardinality = 0..n, target = null, bind = registerStylesheet, unbind = unregisterStylesheet]
Invalid type stored in transient data with the key binding
Aug 11, 2015 11:51:16 PM org.eclipse.fx.ui.workbench.renderers.fx.DefWindowRenderer$WWindowImpl <init>
WARNUNG: Useage of deprecated persisted state 'fx.stage.decoration' please use 'efx.window.decoration.fxml' instead.
Creating controller ....
!ENTRY org.eclipse.equinox.event 4 0 2015-08-11 23:51:17.062
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/UIElement/widget/SET] {ChangedElement=org.eclipse.e4.ui.model.application.ui.basic.impl.TrimmedWindowImpl@fab5409 (elementId: org.efxclipse.e4.mainWindow, tags: [], contributorURI: platform:/plugin/media) (widget: org.eclipse.fx.ui.workbench.renderers.fx.DefWindowRenderer$WWindowImpl@3a777b22, renderer: org.eclipse.fx.ui.workbench.renderers.fx.DefWindowRenderer@17b50892, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: Media Application, iconURI: null, tooltip: null, context: TrimmedWindowImpl (org.efxclipse.e4.mainWindow) Context, variables: [], x: 30, y: 30, width: 1024, height: 768), Widget=org.eclipse.fx.ui.workbench.renderers.fx.DefWindowRenderer$WWindowImpl@3a777b22, AttName=widget, NewValue=org.eclipse.fx.ui.workbench.renderers.fx.DefWindowRenderer$WWindowImpl@3a777b22, EventType=SET} to handler org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler@ea36b25
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.ClassCastException: org.eclipse.fx.ui.workbench.renderers.fx.DefWindowRenderer$WWindowImpl cannot be cast to org.eclipse.swt.widgets.Widget
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:68)
at org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler$1.run(UIEventObjectSupplier.java:56)
at org.eclipse.fx.ui.workbench.fx.internal.UISynchronizeImpl.syncExec(UISynchronizeImpl.java:88)
at org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler.handleEvent(UIEventObjectSupplier.java:53)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:85)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:59)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setWidget(UIElementImpl.java:261)
at org.eclipse.fx.ui.workbench.renderers.base.BaseRenderer.bindWidget(BaseRenderer.java:547)
at org.eclipse.fx.ui.workbench.renderers.base.BaseRenderer.bindWidget(BaseRenderer.java:1)
at org.eclipse.fx.ui.workbench.fx.PartRenderingEngine.createWidget(PartRenderingEngine.java:247)
at org.eclipse.fx.ui.workbench.fx.PartRenderingEngine.createGui(PartRenderingEngine.java:211)
at org.eclipse.fx.ui.workbench.fx.PartRenderingEngine.createGui(PartRenderingEngine.java:311)
at org.eclipse.fx.ui.workbench.fx.PartRenderingEngine.run(PartRenderingEngine.java:439)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.fx.ui.workbench.fx.E4Application$1.lambda$0(E4Application.java:181)
at org.eclipse.fx.ui.workbench.fx.E4Application$1$$Lambda$63/966136923.run(Unknown Source)
at org.eclipse.fx.ui.workbench.fx.E4Application$1.run(E4Application.java:170)
at org.eclipse.fx.ui.workbench.fx.E4Application.jfxStart(E4Application.java:193)
at org.eclipse.fx.ui.workbench.fx.DefaultJFXApp.start(DefaultJFXApp.java:57)
at com.sun.javafx.application.LauncherImpl.lambda$launchApplication1$159(Unknown Source)
at com.sun.javafx.application.LauncherImpl$$Lambda$58/1857059779.run(Unknown Source)
at com.sun.javafx.application.PlatformImpl.lambda$runAndWait$172(Unknown Source)
at com.sun.javafx.application.PlatformImpl$$Lambda$54/788707394.run(Unknown Source)
at com.sun.javafx.application.PlatformImpl.lambda$null$170(Unknown Source)
at com.sun.javafx.application.PlatformImpl$$Lambda$56/1865261172.run(Unknown Source)
at com.sun.javafx.application.PlatformImpl.lambda$runLater$171(Unknown Source)
at com.sun.javafx.application.PlatformImpl$$Lambda$55/713845900.run(Unknown Source)
at com.sun.glass.ui.InvokeLaterDispatcher$Future.run(Unknown Source)
at com.sun.glass.ui.win.WinApplication._runLoop(Native Method)
at com.sun.glass.ui.win.WinApplication.lambda$null$145(Unknown Source)
at com.sun.glass.ui.win.WinApplication$$Lambda$44/1741750503.run(Unknown Source)
Caused by: java.lang.ClassCastException: org.eclipse.fx.ui.workbench.renderers.fx.DefWindowRenderer$WWindowImpl cannot be cast to org.eclipse.swt.widgets.Widget
at org.eclipse.e4.ui.workbench.addons.dndaddon.DnDAddon.subscribeTopicWidget(DnDAddon.java:38)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
... 42 more
Re: Cannot run Media Application sample under e(fx)clipse 2.0 [message #1705122 is a reply to message #1705116] |
Wed, 12 August 2015 09:28   |
Thanks for the quick reply.
I did not mean to port an SWT app to JavaFX.
I simply created a new "e4 Media Application" sample project
(New ->> JavaFX ->> Samples ->> e4 Media Application).
- the launch config contains the necessary "org.osgi.framework.bundle.parent=ext" definition (launchConfiguration.jpg)
- the target platform contains the necessary "Target Platform Feature" (targetPlatform.jpg)
- the product definition is set to "org.eclipse.fx.ui.workbench.fx.application" (productDefinition.jpg)
- there are apparently no "SWT"-dependencies (as far as I can see...)
Moreover, all settings described are unmodified (i.e. they are exactly as created initially by "New ->> e4 Media Application").
I do have an own e4 JavaFX project (no SWT), which also runs with e(fx)clipse 1.2 without problems but throws the same error
with 2.0 (thats why I initially wanted to see if the provided e4 Media Application sample project works under 2.0)
thanks
Re: Cannot run Media Application sample under e(fx)clipse 2.0 [message #1705237 is a reply to message #1705133] |
Thu, 13 August 2015 07:59   |
FYI:
I checked out a fresh "RCP" version of eclipse mars, installed the tooling and adapted the runtime accordingly (as I did with the luna versions before) and everything works out-of-the-box.
I suppose the problems I faced have to do with the provided e(fx)clipse "all-in-one-build", somehow.
best regards
Michael
Re: Cannot run Media Application sample under e(fx)clipse 2.0 [message #1705254 is a reply to message #1705122] |
Thu, 13 August 2015 10:30   |
Your target platform setup is simply wrong - you should not have the
eclipse install into your target!
Tom
On 12.08.15 11:28, Michael Marton wrote:
> Hi
> thanks
Re: Cannot run Media Application sample under e(fx)clipse 2.0 [message #1705255 is a reply to message #1705237] |
Thu, 13 August 2015 10:33   |
I don't think so - to me it looks like your target setup in the previous
post is simply wrong and if the Eclipse install in your target you have
a big problem because then you eg have multiple javax.annotation
provides, multiple javax.xml providers, ... and things start to blow up
as you've seen it happening.
Tom
On 13.08.15 09:59, Michael Marton wrote:
> FYI:
> best regards
> Michael
Re: Cannot run Media Application sample under e(fx)clipse 2.0 [message #1705275 is a reply to message #1705265] |
Thu, 13 August 2015 12:05   |
You never extend the running platform! You create a new empty one and
only add the e(fx)clipse target feature!
Tom
On 13.08.15 13:25, Michael Marton wrote:
> Hi
> It was also my first idea that something with the target platform is wrong.
> If I use the original "all-in-one" eclipse distro and create a new "e4 sample media" project (without doing any changes to the project/workspace settings), some dependencies are missing (missingDependencies.jpg).
> Thats why I extended the contained "Running Platform" target with the runtime bundles from http://download.eclipse.org/efxclipse/runtime-released/2.0.0/site.
> It could well be that this was the problem.
> Michael
Re: Cannot run Media Application sample under e(fx)clipse 2.0 [message #1705278 is a reply to message #1705275] |
Thu, 13 August 2015 12:22  |
Ok, now things get clearer. That might have been my fault then.
In the previous e(fx)clipse versions I always used to install the runtime and
tooling by myself (creating a separate Target, as you mentioned).
This time I thought I'll go with the "all-in-one" package to give it a quick try
(thinking that "all-in-one" means the runtime bundles are already present...).
thanks for the support
Michael
FUDForum. Page generated in 0.04652 seconds
