Home » Eclipse Projects » Paho » Paho MQQTT Client get an java.util.concurrent.TimeoutException
Paho MQQTT Client get an java.util.concurrent.TimeoutException [message #1705072] |
Tue, 11 August 2015 19:50 |
Guy Yannick Messages: 2 Registered: August 2015 |
Test Env.
Paho MQTT Client 1.0.2
Mosquitto 1.4.2
JEE 7
I'm trying to implement a MQTT client with Paho. The Client launch (subscribe a specific topic) on the MQTT Broker to receive messages from an Android App.
After the first publish, it's not more possible to sent/receive messages. My jboss becomes completely crazy .Hier my code and logs ....
@Startup
@Singleton
public class AppliMqttClient implements MqttCallback {
// Mqtt topics
private final String SUBSCRIPTION_TOPIC_BASE = "DBSY/IMPROW/Appli3/CLIENT";
private final String SUBSCRIPTION_TOPIC_OUT = SUBSCRIPTION_TOPIC_BASE + "/OUT/";
private final String SUBSCRIPTION_TOPIC = SUBSCRIPTION_TOPIC_OUT + "+"; // Single-level
// Broker connnections data
private static final String BROKER_URL = "tcp://localhost:1883";
private static final String MQTT_CLIENT_ID = "EXPERTEN_BACKEND";
private static final int QoS = 2;
@EJB
private AppliFacade facade;
private MqttClient client;
private MqttConnectOptions connOpts;
private ObjectMapper mapper;
private String messageId;
@PostConstruct
public void start() {
try {
// connection options
connOpts = new MqttConnectOptions();
connOpts.setKeepAliveInterval(120);
connOpts.setCleanSession(false);
client = new MqttClient(BROKER_URL, MQTT_CLIENT_ID);
client.setCallback(this);
connect();
client.subscribe(SUBSCRIPTION_TOPIC, QoS);
} catch (MqttException me) {
log.error("Connection to " + BROKER_URL + "failed");
logMqttException(me);
* Method to connect to the broker
private void connect() {
// Tying a cycle of reconnects.
boolean tryConnecting = true;
while (tryConnecting) {
try {
client.connect(connOpts);
} catch (Exception e1) {
log.error("Connection attempt failed with '" + e1.getCause() + "'. Retrying.");
// TODO YF: track the number of attempts
if (client.isConnected()) {
log.info("Connected to " + BROKER_URL);
tryConnecting = false;
} else {
pause();
* Method to publish the message
* @param topic
* The topic of the message
* @param pubMsg
* The message to publish
private void publishAMessage(String topic, String pubMsg) {
MqttMessage message = new MqttMessage(pubMsg.getBytes());
message.setQos(QoS);
// Publish the message
log.info("Publishing to topic \"" + topic + "\" qos " + QoS);
try {
// Publish to the broker
client.publish(topic, message);
// Wait until the message has been delivered to the broker
logOutgoingMessage(topic, message);
} catch (Exception e) {
log.error("Publishing to topic \"" + topic + "\" qos " + QoS + "failed.", e);
* Determine the service to invoke
* @throws JsonProcessingException
private String handleRquest(AbstractRequest request) throws JsonProcessingException {
private String handelUserRequest(AbstractRequest request) throws JsonProcessingException {
private String handelExpertRequest(AbstractRequest request) throws JsonProcessingException {
return jsonResp;
public void messageArrived(String topic, MqttMessage message) throws Exception {
// generate the response message ID
messageId = "EB" + System.currentTimeMillis();
// log the message
logIncomingMessage(topic, message);
// handle the message
AbstractRequest request = getMapper().readValue(message.toString(), AbstractRequest.class);
// handle the request
String jsonResp = handleRquest(request);
// publish message
publishAMessage(request.getReplyTopic(), jsonResp);
* Method callback is invoked when a message published by this client is
* successfully received by the broker.
public void deliveryComplete(IMqttDeliveryToken token) {
// NOT NEEDED
public void connectionLost(Throwable cause) {
log.error("Connection lost - attempting reconnect");
if (cause instanceof MqttException) {
MqttException me = (MqttException) cause;
log.info("---------------ERROR------------------------------");
log.error("| Reason: " + me.getReasonCode());
log.error("| Msg: " + me.getMessage());
log.error("| Loc: " + me.getLocalizedMessage());
log.error("| Cause: " + me.getCause());
// reconnect
connect();
20:20:12,539|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsTokenStore||EXPERTEN_BACKEND: key=Ping
20:20:12,539|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: ping response received. pingOutstanding: 0
20:20:12,539|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsReceiver||EXPERTEN_BACKEND: network read message
20:20:17,445|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: received bytes count=1
20:20:17,445|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: received bytes count=2
20:20:17,446|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream||null: 501
20:20:17,446|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: received key=1 message=PUBREL msgId 1
20:20:17,446|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: new msg avail, notify workAvailable
20:20:17,446|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsReceiver||EXPERTEN_BACKEND: network read message
20:20:38,559|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: received bytes count=1
20:20:38,559|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: received bytes count=2
20:20:38,559|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream||null: 501
20:20:38,559|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: received key=1 message=PUBREL msgId 1
20:20:38,559|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: new msg avail, notify workAvailable
20:20:38,559|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsReceiver||EXPERTEN_BACKEND: network read message
20:20:39,055|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: received bytes count=1
20:20:39,055|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: received bytes count=44
20:20:39,055|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream||null: 501
20:20:39,055|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: received key=0 message=PUBLISH qos:0 retained:false dup:false topic:"DBSY/IMPROW/MAYDAY3/CLIENT/OUT/12345-12345" payload:[hex: utf8:"" length:0]
20:20:39,055|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: new msg avail, notify workAvailable
20:20:39,056|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsReceiver||EXPERTEN_BACKEND: network read message
20:20:59,576|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: received bytes count=1
20:20:59,576|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: received bytes count=2
20:20:59,576|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream||null: 501
20:20:59,576|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: received key=1 message=PUBREL msgId 1
20:20:59,576|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: new msg avail, notify workAvailable
20:20:59,576|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsReceiver||EXPERTEN_BACKEND: network read message
20:21:20,597|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: received bytes count=1
20:21:20,597|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: received bytes count=2
20:21:20,597|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream||null: 501
20:21:20,597|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: received key=1 message=PUBREL msgId 1
20:21:20,597|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: new msg avail, notify workAvailable
20:21:20,597|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsReceiver||EXPERTEN_BACKEND: network read message
20:21:37,199|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: received bytes count=1
20:21:37,199|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: received bytes count=4420:21:37,200|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream||null: 501
20:21:37,200|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: received key=0 message=PUBLISH qos:0 retained:false dup:false topic:"DBSY/IMPROW/MAYDAY3/CLIENT/OUT/12345-12345" payload:[hex: utf8:"" length:0]
20:21:37,200|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:21:37,400|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:21:37,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:22:11,800|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:22:12,000|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:22:12,200|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:22:12,400|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:22:12,538|FINE|MQTT Ping: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.TimerPingSender||null: Check schedule at 1.439.317.332.538
20:22:12,538|FINE|MQTT Ping: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: checkForActivity entered
20:22:12,538|FINE|MQTT Ping: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: ping needed. keepAlive=120.000 lastOutboundActivity=1.439.317.212.539 lastInboundActivity=1.439.317.297.200
20:22:12,538|FINE|MQTT Ping: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsTokenStore||EXPERTEN_BACKEND: key=Ping message=PINGREQ
20:22:12,538|FINE|MQTT Ping: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsTokenStore||EXPERTEN_BACKEND: key=Ping token=org.eclipse.paho.client.mqttv3.MqttToken@35cc7bb0
20:22:12,538|FINE|MQTT Ping: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: notifying queueLock holders
20:22:12,538|FINE|MQTT Ping: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: Schedule next ping at 120.000
20:22:12,538|FINE|MQTT Snd: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: new work or ping arrived
20:22:12,538|FINE|MQTT Snd: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsSender||EXPERTEN_BACKEND: network send key=Ping msg=PINGREQ
20:22:12,538|FINE|MQTT Snd: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: connected
20:22:12,538|FINE|MQTT Snd: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.wire.MqttOutputStream||null: 500
20:22:12,538|FINE|MQTT Snd: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: key=Ping
20:22:12,538|FINE|MQTT Snd: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.Token||EXPERTEN_BACKEND: > key=Ping
20:22:12,538|FINE|MQTT Snd: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: ping sent. pingOutstanding: 1
20:22:12,538|FINE|MQTT Snd: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: wait for new work or for space in the inflight window
20:22:12,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:22:12,800|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:22:13,000|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:22:13,200|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:22:13,400|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:22:13,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:22:13,800|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:22:14,000|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:22:14,200|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:22:16,400|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:04,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:04,800|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:04,866|ERROR|Controller Boot Thread|org.jboss.as.controller.management-operation||JBAS013412: Timeout nach [300] Warten auf Service Container Stabilität. Operation wird zurückgesetzt. Der Schritt der den Service Container zuerst aktualisiert hat war 'add' an Adresse '[
("core-service" => "management"),
("management-interface" => "native-interface")
20:23:04,880|INFO|ServerService Thread Pool -- 71|org.jboss.web||JBAS018224: Deregistrierung von Webkontext: /inetcheck
20:23:04,881|INFO|ServerService Thread Pool -- 73|org.jboss.web||JBAS018224: Deregistrierung von Webkontext: /mayday/alivecheck
20:23:04,882|INFO|ServerService Thread Pool -- 72|org.jboss.web||JBAS018224: Deregistrierung von Webkontext: /mayday
20:23:04,896|INFO|ServerService Thread Pool -- 72|stdout|||3.2.2|INFO|ap-State|core.ApplicationStopping||Unknown reason||||||Die Anwendung wird gestoppt: Unknown reason||BK7N00008035|mayday|...kend\impl\servers\jboss\target\standalone\log/mayday-tech.log|mayday-jboss|4|||||1|Tech
20:23:04,902|INFO|ServerService Thread Pool -- 72|stdout|||INFO|de.dbsystems.kolt.talo.tools.servlet.LogServlet|ap-State|core.ApplicationStopping||||Unknown reason|Die Anwendung wird gestoppt: Unknown reason|BK7N00008035|mayday|mayday-jboss||||
20:23:04,908|INFO|ServerService Thread Pool -- 72|stdout|||3.2.2|INFO|ap-State|core.ApplicationStopped||Unknown Reason||||||Die Anwendung wurde gestoppt: Unknown Reason||BK7N00008035|mayday|...kend\impl\servers\jboss\target\standalone\log/mayday-tech.log|mayday-jboss|4|||||1|Tech
20:23:04,909|INFO|ServerService Thread Pool -- 72|stdout|||INFO|de.dbsystems.kolt.talo.tools.servlet.LogServletContextListener|ap-State|core.ApplicationStopped||||Unknown Reason|Die Anwendung wurde gestoppt: Unknown Reason|BK7N00008035|mayday|mayday-jboss||||
20:23:04,932|INFO|MSC service thread 1-14|org.jboss.as.server.deployment||JBAS015877: Deployment von inetcheck.war in (runtime-name: "inetcheck.war") 63ms gestoppt
20:23:04,901|WARN|ServerService Thread Pool -- 66|org.jboss.as.ee||JBAS011005: Löschung der Komponenteninstanz org.jboss.as.ejb3.component.singleton.SingletonComponentInstance@38a7f10c fehlgeschlagen: javax.ejb.EJBException: java.lang.IllegalStateException: JBAS011424: Container-gemanagter Entity-Manager kann nur vom Container geschlossen werden (automatisch geleert bei Transaktions-/Aufruf-Ende und geschlossen, wenn besitzende Komponente geschlossen wird.)
at org.jboss.as.ejb3.tx.CMTTxInterceptor.handleExceptionInOurTx(CMTTxInterceptor.java:189)
at org.jboss.as.ejb3.tx.CMTTxInterceptor.invokeInOurTx(CMTTxInterceptor.java:274)
at org.jboss.as.ejb3.tx.CMTTxInterceptor.requiresNew(CMTTxInterceptor.java:368)
at org.jboss.as.ejb3.tx.LifecycleCMTTxInterceptor.processInvocation(LifecycleCMTTxInterceptor.java:66)
at org.jboss.invocation.InterceptorContext.proceed(InterceptorContext.java:288)
at org.jboss.as.ejb3.component.interceptors.CurrentInvocationContextInterceptor.processInvocation(CurrentInvocationContextInterceptor.java:41)
at org.jboss.invocation.ContextClassLoaderInterceptor.processInvocation(ContextClassLoaderInterceptor.java:70)
at org.jboss.invocation.ChainedInterceptor.processInvocation(ChainedInterceptor.java:61)
at org.jboss.as.ee.component.BasicComponentInstance.destroy(BasicComponentInstance.java:126)
at org.jboss.as.ejb3.component.singleton.SingletonComponent.destroySingletonInstance(SingletonComponent.java:187)
at org.jboss.as.ejb3.component.singleton.SingletonComponent.stop(SingletonComponent.java:144)
at org.jboss.as.ee.component.ComponentStartService$2.run(ComponentStartService.java:72)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
at org.jboss.threads.JBossThread.run(JBossThread.java:122)
Caused by: java.lang.IllegalStateException: JBAS011424: Container-gemanagter Entity-Manager kann nur vom Container geschlossen werden (automatisch geleert bei Transaktions-/Aufruf-Ende und geschlossen, wenn besitzende Komponente geschlossen wird.)
at org.jboss.as.jpa.container.TransactionScopedEntityManager.close(TransactionScopedEntityManager.java:100)
at de.db.mayday.facade.ImportExportBean.flushDataBase(ImportExportBean.java:64)
at java.lang.reflect.Method.invoke(Method.java:483)
at org.jboss.as.ee.component.ManagedReferenceLifecycleMethodInterceptor.processInvocation(ManagedReferenceLifecycleMethodInterceptor.java:96)
at org.jboss.invocation.WeavedInterceptor.processInvocation(WeavedInterceptor.java:53)
at org.jboss.as.ee.component.ManagedReferenceReleaseInterceptor.processInvocation(ManagedReferenceReleaseInterceptor.java:57)
at org.jboss.as.ee.component.NamespaceContextInterceptor.processInvocation(NamespaceContextInterceptor.java:50)
at org.jboss.as.ejb3.tx.CMTTxInterceptor.invokeInOurTx(CMTTxInterceptor.java:272)
... 18 more
20:23:05,000|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:05,200|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:09,200|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:09,400|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:09,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:09,800|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:09,867|ERROR|Controller Boot Thread|org.jboss.as.controller.client||JBAS014781: Step-Handler org.jboss.as.server.DeployerChainAddHandler$FinalRuntimeStepHandler@7330ff03 für Operation {"operation" => "add-deployer-chains","address" => []} an Adresse [] für Zurücksetzen der Operation -- java.util.concurrent.TimeoutException fehlgeschlagen
20:23:10,000|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:10,141|WARN|Transaction Reaper|com.arjuna.ats.arjuna||ARJUNA012117: TransactionReaper::check timeout for TX 0:ffff0ab44d04:-12006810:55ca3c5d:e in state RUN
20:23:10,142|WARN|Transaction Reaper Worker 0|com.arjuna.ats.arjuna||ARJUNA012095: Abort of action id 0:ffff0ab44d04:-12006810:55ca3c5d:e invoked while multiple threads active within it.
20:23:10,143|WARN|Transaction Reaper Worker 0|com.arjuna.ats.arjuna||ARJUNA012108: CheckedAction::check - atomic action 0:ffff0ab44d04:-12006810:55ca3c5d:e aborting with 1 threads active!
20:23:10,143|WARN|Transaction Reaper Worker 0|com.arjuna.ats.arjuna||ARJUNA012121: TransactionReaper::doCancellations worker Thread[Transaction Reaper Worker 0,5,main] successfully canceled TX 0:ffff0ab44d04:-12006810:55ca3c5d:e
20:23:10,200|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:10,262|INFO|Timer-1|stdout|||3.2.2|INFO|mo-Logging|core.TaloAlive||3.5.2|1|300||||Logging-Pfad zum Cockpit alive. TALOImpl: 3.5.2||BK7N00008035|mayday||mayday-jboss|4|||||1|
20:23:10,400|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:10,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:14,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:14,800|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:14,867|ERROR|Controller Boot Thread|org.jboss.as.controller.client||JBAS014781: Step-Handler org.jboss.as.domain.management.security.SecurityRealmAddHandler$ServiceInstallStepHandler@721be840 für Operation {"address" => [("core-service" => "management"),("security-realm" => "ApplicationRealm")],"operation" => "add","map-groups-to-roles" => undefined} an Adresse [
20:23:14,868|CONFIG|MSC service thread 1-12|com.sun.net.httpserver||context removed: /
20:23:14,868|CONFIG|MSC service thread 1-12|com.sun.net.httpserver||context removed: /management
20:23:14,868|CONFIG|MSC service thread 1-12|com.sun.net.httpserver||context removed: /console
20:23:14,868|CONFIG|MSC service thread 1-12|com.sun.net.httpserver||context removed: /error
20:23:14,868|CONFIG|MSC service thread 1-12|com.sun.net.httpserver||context removed: /logout
20:23:15,000|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:15,200|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:15,400|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:15,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:15,800|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:16,000|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:16,200|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:19,000|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:19,200|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:19,400|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:19,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:19,800|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:19,867|ERROR|Controller Boot Thread|org.jboss.as.controller.client||JBAS014781: Step-Handler org.jboss.as.domain.management.security.SecurityRealmAddHandler$ServiceInstallStepHandler@721be840 für Operation {"address" => [("core-service" => "management"),("security-realm" => "ManagementRealm")],"operation" => "add","map-groups-to-roles" => undefined} an Adresse [
20:23:19,868|ERROR|ServerService Thread Pool -- 29|org.jboss.as.server||JBAS015871: Deploy von Deployment "mayday.ear" wurde ohne Fehlermeldung zurückgesetzt
20:23:19,868|ERROR|ServerService Thread Pool -- 29|org.jboss.as.server||JBAS015871: Deploy von Deployment "inetcheck.war" wurde ohne Fehlermeldung zurückgesetzt
20:23:19,875|INFO|MSC service thread 1-8|org.apache.coyote.ajp||JBWEB003048: Pausing Coyote AJP/1.3 on ajp-/0.0.0.0:8009
20:23:19,875|INFO|MSC service thread 1-8|org.apache.coyote.ajp||JBWEB003051: Stopping Coyote AJP/1.3 on ajp-/0.0.0.0:8009
20:23:19,882|INFO|MSC service thread 1-9|org.apache.coyote.http11.Http11Protocol||JBWEB003075: Coyote HTTP/1.1 pausing on: http-/0.0.0.0:8080
20:23:19,882|INFO|MSC service thread 1-9|org.apache.coyote.http11.Http11Protocol||JBWEB003077: Coyote HTTP/1.1 stopping on : http-/0.0.0.0:8080
20:23:23,400|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:23,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:23,800|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:24,000|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:24,200|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:24,400|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:24,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:24,800|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:24,880|ERROR|Controller Boot Thread|org.jboss.as.controller.client||JBAS014781: Step-Handler org.jboss.as.controller.ParallelBootOperationStepHandler$2@5bdb19eb für Operation {"operation" => "parallel-subsystem-boot","address" => []} an Adresse [] für Zurücksetzen der Operation -- java.util.concurrent.TimeoutException fehlgeschlagen
20:23:25,000|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:25,200|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:25,400|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:29,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:29,800|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:29,880|ERROR|Controller Boot Thread|org.jboss.as.controller.client||JBAS014781: Step-Handler org.jboss.as.controller.AbstractAddStepHandler$1@6642e014 für Operation {"operation" => "add","host" => "localhost","port" => 25,"address" => [("socket-binding-group" => "standard-sockets"),("remote-destination-outbound-socket-binding" => "mail-smtp")],"source-interface" => undefined,"source-port" => undefined,"fixed-source-port" => undefined} an Adresse [
20:23:30,000|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:30,200|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:30,400|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:30,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:30,800|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:31,000|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:31,200|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:34,400|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:34,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:34,800|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:34,880|ERROR|Controller Boot Thread|org.jboss.as.controller.client||JBAS014781: Step-Handler org.jboss.as.controller.AbstractAddStepHandler$1@6ec5b95c für Operation {"address" => [("socket-binding-group" => "standard-sockets"),("socket-binding" => "txn-status-manager")],"operation" => "add","port" => 4713,"interface" => undefined,"fixed-port" => undefined,"multicast-address" => undefined,"multicast-port" => undefined,"client-mappings" => undefined} an Adresse [
20:23:35,000|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:35,200|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:35,400|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:39,400|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:39,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:39,800|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:39,880|ERROR|Controller Boot Thread|org.jboss.as.controller.client||JBAS014781: Step-Handler org.jboss.as.controller.AbstractAddStepHandler$1@31348875 für Operation {"address" => [("socket-binding-group" => "standard-sockets"),("socket-binding" => "txn-recovery-environment")],"operation" => "add","port" => 4712,"interface" => undefined,"fixed-port" => undefined,"multicast-address" => undefined,"multicast-port" => undefined,"client-mappings" => undefined} an Adresse [
20:23:40,000|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:40,200|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:40,400|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:40,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:40,800|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:44,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:44,800|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:44,880|ERROR|Controller Boot Thread|org.jboss.as.controller.client||JBAS014781: Step-Handler org.jboss.as.controller.AbstractAddStepHandler$1@8da18e9 für Operation {"address" => [("socket-binding-group" => "standard-sockets"),("socket-binding" => "remoting")],"operation" => "add","port" => 4447,"interface" => undefined,"fixed-port" => undefined,"multicast-address" => undefined,"multicast-port" => undefined,"client-mappings" => undefined} an Adresse [
20:23:45,000|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:45,200|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:45,400|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:45,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:45,800|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:46,000|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:49,400|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:49,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:49,800|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:49,880|ERROR|Controller Boot Thread|org.jboss.as.controller.client||JBAS014781: Step-Handler org.jboss.as.controller.AbstractAddStepHandler$1@6152dc9a für Operation {"address" => [("socket-binding-group" => "standard-sockets"),("socket-binding" => "osgi-http")],"operation" => "add","interface" => "management","port" => 8090,"fixed-port" => undefined,"multicast-address" => undefined,"multicast-port" => undefined,"client-mappings" => undefined} an Adresse [
20:23:50,000|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:50,200|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:50,400|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:53,800|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:54,000|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:54,200|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:54,400|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:54,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:54,800|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:54,880|ERROR|Controller Boot Thread|org.jboss.as.controller.client||JBAS014781: Step-Handler org.jboss.as.controller.AbstractAddStepHandler$1@40c493a0 für Operation {"address" => [("socket-binding-group" => "standard-sockets"),("socket-binding" => "https")],"operation" => "add","port" => 8443,"interface" => undefined,"fixed-port" => undefined,"multicast-address" => undefined,"multicast-port" => undefined,"client-mappings" => undefined} an Adresse [
20:23:55,000|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:55,200|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:55,400|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:55,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:55,800|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:59,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:59,800|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:23:59,880|ERROR|Controller Boot Thread|org.jboss.as.controller.client||JBAS014781: Step-Handler org.jboss.as.controller.AbstractAddStepHandler$1@47ef603f für Operation {"address" => [("socket-binding-group" => "standard-sockets"),("socket-binding" => "http")],"operation" => "add","port" => 8080,"interface" => undefined,"fixed-port" => undefined,"multicast-address" => undefined,"multicast-port" => undefined,"client-mappings" => undefined} an Adresse [
20:24:00,000|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:24:00,200|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:24:00,400|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:24:00,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:24:00,800|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:24:01,000|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:24:01,200|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:24:04,400|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:24:04,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:24:04,800|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:24:04,880|ERROR|Controller Boot Thread|org.jboss.as.controller.client||JBAS014781: Step-Handler org.jboss.as.controller.AbstractAddStepHandler$1@352dd44f für Operation {"address" => [("socket-binding-group" => "standard-sockets"),("socket-binding" => "ajp")],"operation" => "add","port" => 8009,"interface" => undefined,"fixed-port" => undefined,"multicast-address" => undefined,"multicast-port" => undefined,"client-mappings" => undefined} an Adresse [
20:24:05,000|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:24:05,200|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:24:05,400|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:24:05,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:24:05,800|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:24:06,000|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:24:06,200|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:24:06,400|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:24:06,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:24:06,800|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:24:09,000|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:24:09,200|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:24:09,400|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:24:09,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:24:09,800|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:24:09,880|ERROR|Controller Boot Thread|org.jboss.as.controller.client||JBAS014781: Step-Handler org.jboss.as.controller.AbstractAddStepHandler$1@4ff25db9 für Operation {"address" => [("socket-binding-group" => "standard-sockets"),("socket-binding" => "management-https")],"operation" => "add","interface" => "management","port" => expression "${jboss.management.https.port:9443}","fixed-port" => undefined,"multicast-address" => undefined,"multicast-port" => undefined,"client-mappings" => undefined} an Adresse [
20:24:10,000|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:24:12,200|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:24:12,400|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: wait for spaceAvailable
20:24:12,538|FINE|MQTT Ping: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.TimerPingSender||null: Check schedule at 1.439.317.452.538
20:24:12,538|FINE|MQTT Ping: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: checkForActivity entered
20:24:12,538|SEVERE|MQTT Ping: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: Timed out as no activity, keepAlive=120.000 lastOutboundActivity=1.439.317.332.538 lastInboundActivity=1.439.317.297.200 time=1.439.317.452.538 lastPing=1.439.317.332.538
20:24:12,538|FINE|MQTT Ping: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientComms||EXPERTEN_BACKEND: exception: Zeitlimitüberschreitung beim Warten auf eine Antwort vom Server (32000)
at org.eclipse.paho.client.mqttv3.internal.ExceptionHelper.createMqttException(ExceptionHelper.java:31)
at org.eclipse.paho.client.mqttv3.internal.ClientState.checkForActivity(ClientState.java:564)
at org.eclipse.paho.client.mqttv3.internal.ClientComms.checkForActivity(ClientComms.java:660)
at org.eclipse.paho.client.mqttv3.TimerPingSender$PingTask.run(TimerPingSender.java:77)
at java.util.TimerThread.mainLoop(Timer.java:555)
at java.util.TimerThread.run(Timer.java:505)
20:24:12,540|FINE|MQTT Ping: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientComms||EXPERTEN_BACKEND: state=DISCONNECTING
20:24:12,540|FINE|MQTT Ping: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: stopping
20:24:12,540|FINE|MQTT Ping: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: notify workAvailable and wait for run
20:24:12,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: new msg avail, notify workAvailable
20:24:12,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsReceiver||EXPERTEN_BACKEND: network read message
20:24:12,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: received bytes count=1
20:24:12,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: received bytes count=2
20:24:12,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream||null: 501
20:24:12,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: received key=1 message=PUBREL msgId 1
20:24:12,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: received key=0 message=PINGRESP msgId 0
20:24:12,600|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.Token||EXPERTEN_BACKEND: >key=Ping response=PINGRESP msgId 0 excep=null
20:24:12,601|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: keyPing, msg=PINGRESP msgId 0, excep=null
20:24:12,601|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: callback and notify for key=Ping
20:24:12,601|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.Token||EXPERTEN_BACKEND: >key=Ping response=PINGRESP msgId 0 excep=null
20:24:12,601|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: received key=0 token=org.eclipse.paho.client.mqttv3.MqttToken@35cc7bb0 message=PINGRESP msgId 0
20:24:12,601|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsTokenStore||EXPERTEN_BACKEND: key=Ping
20:24:12,601|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: ping response received. pingOutstanding: 0
20:24:12,601|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsReceiver||EXPERTEN_BACKEND: network read message
20:24:12,601|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: received bytes count=1
20:24:12,601|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: received bytes count=2
20:24:12,601|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream||null: 501
20:24:12,601|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: received key=1 message=PUBREL msgId 1
20:24:12,601|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: new msg avail, notify workAvailable
20:24:12,602|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream||null: 501
20:24:12,602|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: received key=1 message=PUBREL msgId 1
20:24:12,602|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsCallback||EXPERTEN_BACKEND: new msg avail, notify workAvailable
20:24:12,602|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.CommsReceiver||EXPERTEN_BACKEND: network read message
20:24:12,602|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: received bytes count=1
20:24:12,602|FINE|MQTT Rec: EXPERTEN_BACKEND|org.eclipse.paho.client.mqttv3.internal.ClientState||EXPERTEN_BACKEND: received bytes count=2
20:24:14,880|ERROR|Controller Boot Thread|org.jboss.as.controller.client||JBAS014781: Step-Handler org.jboss.as.controller.AbstractAddStepHandler$1@45c5b25c für Operation {"address" => [("socket-binding-group" => "standard-sockets"),("socket-binding" => "management-http")],"operation" => "add","interface" => "management","port" => expression "${jboss.management.http.port:9990}","fixed-port" => undefined,"multicast-address" => undefined,"multicast-port" => undefined,"client-mappings" => undefined} an Adresse [
20:24:19,880|ERROR|Controller Boot Thread|org.jboss.as.controller.client||JBAS014781: Step-Handler org.jboss.as.controller.AbstractAddStepHandler$1@6afe48a0 für Operation {"address" => [("socket-binding-group" => "standard-sockets"),("socket-binding" => "management-native")],"operation" => "add","interface" => "management","port" => expression "${jboss.management.native.port:9999}","fixed-port" => undefined,"multicast-address" => undefined,"multicast-port" => undefined,"client-mappings" => undefined} an Adresse [
20:24:24,880|ERROR|Con
Current Time: Thu Apr 25 07:49:35 GMT 2024
Powered by FUDForum. Page generated in 0.02812 seconds
