Home » Language IDEs » C / C++ IDE (CDT) » Work on a remote project with Eclipse via SSH and SVN+SSH(Work on a remote project with Eclipse via SSH (with two remote Linux))
Work on a remote project with Eclipse via SSH and SVN+SSH [message #1704997] Tue, 11 August 2015 10:19 Go to next message
Always Student is currently offline Always StudentFriend
I have the following boxes:
a) A Windows box with Eclipse CDT(or PTP)
b) A Linux box,including Compiler, accessible for me only via SSH.
c) A Linux box, including SVN Source, accessible for me only via SSH
Both the compiler and the hardware required to build and run my project is only on machine B.
I'd like to work "transparently" from a Windows box on that project using Eclipse CDT -or PTP - and be able to build, run and debug the project remotely from within the IDE.
How do I set up that:
The building will work? Any simpler solutions than writing a local makefile which would rsync the project and then call a remote makefile to initiate the actual build? Does Eclipse managed build have a feature for that? The debugging will work? Preferably - the Eclipse CDT -or PTP-code indexing will work? Do I have to copy all required header files from machine B to machine A and add them to include path manually?
[Updated on: Tue, 11 August 2015 10:33]
Report message to a moderator
Re: Work on a remote project with Eclipse via SSH and SVN+SSH [message #1705843 is a reply to message #1704997] Wed, 19 August 2015 12:36 Go to previous message
Arthur Farias is currently offline Arthur FariasFriend
I was trying to use Remote System Project
There is a usefull guide.
http://help.eclipse.org/juno/index.jsp?topic=%2Forg.eclipse.ptp.rdt.doc.user%2Fhtml%2Fgettingstarted%2Fcreating_a_remote_project.html
But I did not have any success.
Previous Topic:Makefiles and SVN plugin with Eclipse Luna
Next Topic:How to combine Eclipse and Xcode (Mac OS X Yosemite)
Current Time: Mon Sep 09 09:06:59 GMT 2024
Powered by FUDForum. Page generated in 0.03256 seconds
