Home » Eclipse Projects » Eclipse Platform » "Enum cannot be resolved", "Enum is not generic" compiler errors
"Enum cannot be resolved", "Enum is not generic" compiler errors [message #326910] Wed, 02 April 2008 20:41 Go to next message
Originally posted by: robert.infotility.com
I am attempting to build (with Eclipse) a project which
successfully builds with ant + javac 1.5.0.
In a file which has some enums, I get some error messages,
"java.lang.Enum cannot be resolved", "Enum is not generic".
I have looked at the project properties and the project
property viewer shows that Compiler compliance level,
Generated .class files compatibility, and Source compatibility
are all set to "5.0". Are there some other properties
I should look at?
There are multiple 1.5.0xxx JDK's on the development box
and no 1.4 or other JDK's.
Sorry if this on is a faq, just point me in the direction
of the standard answer, thanks.
Robert Dodier
Re: "Enum cannot be resolved", "Enum is not generic" compiler errors [message #326912 is a reply to message #326910] Wed, 02 April 2008 21:06 Go to previous messageGo to next message
Robert,
Despite you assurances that there are no 1.4 JDKS on your development
box, it does sound like the JRE being used by Eclipse is a 1.4 JRE.
Check carefully in Window->Preferences->Java->Installed JREs where the
JRE that's being used is coming from...
Robert Dodier wrote:
> Hello,
> I should look at?
> Robert Dodier
Re: "Enum cannot be resolved", "Enum is not generic" compiler errors [message #326951 is a reply to message #326912] Thu, 03 April 2008 11:24 Go to previous message
Originally posted by: eclipse-news.rizzoweb.com
Ed Merks wrote:
> Robert,
Also open the Help > About dialog and click on the Configuration Details
button to see what the java.version and java.vendor values are. That
will tell you what Java Eclipse itself is running on.
Eric
Previous Topic:Dialogs in org.eclipse.ui.workbench JAR
Next Topic:Background color for content assist
Current Time: Fri Nov 07 08:31:27 EST 2025
Powered by FUDForum. Page generated in 0.03371 seconds
