Home » Modeling » Papyrus » Import CSV Data with References to Imported Entities
icon9.gif  Import CSV Data with References to Imported Entities [message #1704167] Fri, 07 August 2015 20:03
Santiago Balestrini is currently offline Santiago BalestriniFriend
I've been trying to import a table that has references between items, e.g., comments.
I've attached two files, one with comments, and the other with Blocks that have an 'OwnedComment' referencing one of the comments.
I created GenericTables and set the paste properties and the columns to import the comments and then the blocks.
It can import the activities correctly, but then when it imports the comments it makes the owner be the parent element that contains the GenericTable.
Ideas and any example of importing linked data with CSVs would be greatly appreciated.
Previous Topic:Model to model transformation
Next Topic:Can Papyrus generate UML from XML or XSD?
Current Time: Mon Mar 01 04:56:38 GMT 2021
Powered by FUDForum. Page generated in 0.01619 seconds
