Home » Archived » Jubula » Ignoring regex on a parameter(Parameter of =PHONENUMBER with a value of +35254646545 fails on test check)
Ignoring regex on a parameter [message #1704136] Fri, 07 August 2015 14:44 Go to next message
Thomas Mortimer is currently offline Thomas MortimerFriend
Hi all,
I have a test case that accepts a parameter of =PHONENUMBER and I use it for two things. First I use it to input text into a textfield, afterwards that text gets sent to the server and it replies with a message, which is put into a tableview.
I then have a check of that tableview looking in the column phone number for the value of =PHONENUMBER. These should be the same value.
The test works fine if I enter a number, like 564654654. But if I enter an international number, like +3524666445252, it fails on the check, with the error message:
Error Description "+3524666445252" is not a regular expression
I've attempted to escape the + by surrounding the parameter =PHONENUMBER with angled brackets, single quotes and I've also done the same on the defined value of +3524666445252, but none of these seem to work.
Is there another method I should be using to escape the + character?
Details on stuff I'm using:
Jubula version: 8.1.6.023
I've attached the test xml file
Let me know if you'd like more information
Tom
Re: Ignoring regex on a parameter [message #1704955 is a reply to message #1704136] Tue, 11 August 2015 06:11 Go to previous messageGo to next message
Alexandra Schladebeck is currently offline Alexandra SchladebeckFriend
Hi Thomas,
Is it necessary that the check uses "matches" as an operator? What happens if you use "equals"?
Alex
Re: Ignoring regex on a parameter [message #1704957 is a reply to message #1704955] Tue, 11 August 2015 06:19 Go to previous messageGo to next message
Thanks for the advice Alexandra, that works fine. Do you have a list somewhere of how the different operators behave? I've been following the cheat sheets and they've always used matches so far, so I replicated that. I would like to know the difference between them, if that is possible?
Thanks for the help!
Tom
Re: Ignoring regex on a parameter [message #1704958 is a reply to message #1704957] Tue, 11 August 2015 06:22 Go to previous message
Hi Tom,
Glad that works! The operator parameter is described in the reference manual: http://help.eclipse.org/mars/topic/org.eclipse.jubula.client.ua.help/content/html/reference/parameters/operator.html?cp=44_2_44
Information about working with matches is here: http://help.eclipse.org/mars/topic/org.eclipse.jubula.client.ua.help/content/html/userManual/tasks/useMatchingAndRegex/using-matching-and-regex.html?cp=45_2_39
The reference manual also contains action and other parameter descriptions.
Hope that helps!
Alex
Previous Topic:Conflict with the component names
Next Topic:Writing jubula tests in java
Current Time: Tue Jan 21 05:49:37 GMT 2025
Powered by FUDForum. Page generated in 0.03113 seconds
