Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Texo] NPE in TexoGeneratorApplication
[Texo] NPE in TexoGeneratorApplication [message #1703980] Thu, 06 August 2015 11:17 Go to next message
Adrian Rumpold is currently offline Adrian RumpoldFriend
I'm having some trouble when invoking Texo's code generation through the Equinox launcher from the command line (I'm trying to integrate the code generation process in my Gradle build setup).
Specifically, I run into a NPE from L352 in
GeneratorUtils.readEPackagesUsingEMFURI(final List<URI> uris, ResourceSet resourceSet, EPackage.Registry registry)
which is invoked in L331 through the overload
GeneratorUtils.readEPackagesUsingEMFURI(final List<URI> uris,  EPackage.Registry registry)
Since the two parameter version supplies null for the ResourceSet, the null pointer access is guaranteed. Maybe the second parameter was intended to be the return value of the otherwise unused method GeneratorUtils.createGenerationResourceSet?
I'm using the latest available version of Texo on Eclipse Mars (0.9.0.v201508051411).
If anybody has encountered this problem before and knows a workaround, I would be most grateful! Thanks for your responses in advance! Smile
Best,
Adrian
Attached stacktrace:
java.lang.RuntimeException: Exception for model file file:/C:/Users/Adriano/MDSD4SIL/EAMetamodel/model/enterprise_architect.ecore
        at org.eclipse.emf.texo.eclipse.generator.TexoGeneratorApplication.generateCode(TexoGeneratorApplication.java:167)
        at org.eclipse.emf.texo.eclipse.generator.TexoGeneratorApplication.start(TexoGeneratorApplication.java:135)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
        at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
        at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
        at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
        at org.eclipse.emf.texo.generator.GeneratorUtils.readEPackagesUsingEMFURI(GeneratorUtils.java:352)
        at org.eclipse.emf.texo.generator.GeneratorUtils.readEPackagesUsingEMFURI(GeneratorUtils.java:331)
        at org.eclipse.emf.texo.eclipse.generator.TexoGeneratorApplication.generateCode(TexoGeneratorApplication.java:174)
        at org.eclipse.emf.texo.eclipse.generator.TexoGeneratorApplication.generateCode(TexoGeneratorApplication.java:165)
My launcher invocation looks like this:
java -jar c:/Users/Adriano/Desktop/Development/eclipse-modeling-mars-R-win32-x86_64/plugins/org.eclipse.equinox.launcher_1.3.100.v20150511-1540.jar -data C:/Users/Adriano/MDSD4SIL -application org.eclipse.emf.texo.eclipse.generator.TexoCodeGenerator -modelLocation C:/Users/Adriano/MDSD4SIL/EAMetamodel/model -projectName EAMetamodel.model
Re: [Texo] NPE in TexoGeneratorApplication [message #1704121 is a reply to message #1703980] Fri, 07 August 2015 12:57 Go to previous messageGo to next message
Martin Taal is currently offline Martin TaalFriend
Indeed a bug.., can you enter a bugzilla for it?
I started to repair it. Should be available by tomorrow.
gr. Martin
On 06-08-15 23:28, Adrian Rumpold wrote:
> which is invoked in L331 through the overload GeneratorUtils.readEPackagesUsingEMFURI(final List<URI> uris,
> responses in advance! :)
> Best,
> Adrian
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
> java -jar
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] NPE in TexoGeneratorApplication [message #1704172 is a reply to message #1704121] Fri, 07 August 2015 20:50 Go to previous messageGo to next message
I published a new build with a bug fix, can you check if it works for you?
If you can still enter a bugzilla for it then I can report against it.
gr. Martin
> gr. Martin
>> Hi,
>> Best,
>> Adrian
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> java -jar
The Netherlands
Re: [Texo] NPE in TexoGeneratorApplication [message #1704882 is a reply to message #1704172] Mon, 10 August 2015 12:10 Go to previous message
Hello Martin,
thanks for your quick reply and the fix! I tested the most recent build and everything seems to be working smoothly now when I invoke the headless code generation.
As you requested, I reported the issue on Bugzilla for reference, you can find it here.
Best,
Adrian
Previous Topic:[EMF Forms] NPE on display reference model dialog
Next Topic:EMF Form
Current Time: Thu Oct 01 22:54:03 GMT 2020
Powered by FUDForum. Page generated in 0.02119 seconds
