[EMF Forms] NPE on display reference model dialog [message #1703939] |
Wed, 05 August 2015 23:56  |
In the EMF Forms View editor I can't display the dialog for creating and
linking reference the reference model to my view model. Pressing on the
button I get the following error (see stack trace below).
This problem occurs on my production Mars Eclipse (many features
installed) on a fresh workspace with only the 3 Makeithappen viewModel
example projects installed.
However, from a newly installed Mars Eclipse Modeling on the same
workspace/projects I can see and get the dialog to display.
So... it looks like some kind of conflict with one or more bundles
running on my production Eclipse and the EMF Forms GUI.
Any ideas - other than starting over with a fresh install?
thanks,
John
Here is that StackTrace...
at org.eclipse.emf.ecp.core.util.ECPUtil.getSubClasses(ECPUtil.java:154)
at
org.eclipse.emf.ecp.view.internal.editor.controls.DomainModelReferenceControlSWTRenderer$SelectionAdapterExtension.widgetSelected(DomainModelReferenceControlSWTRenderer.java:397)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4481)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1327)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3819)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3430)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
at
org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:654)
at
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:598)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:139)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
at org.eclipse.equinox.launcher.Main.main(Main.java:1488)
Re: [EMF Forms] NPE on display reference model dialog [message #1703940 is a reply to message #1703939] |
Thu, 06 August 2015 00:48   |
With some trial and error I found the conflicting feature:
Unfortunately its one of my all time favorites!
https://github.com/mbarbero/fr.obeo.releng.targetplatform
> thanks,
> John
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
> at
> at
> at
> at
> at
> at
> at
> at
Re: [EMF Forms] NPE on display reference model dialog [message #1703941 is a reply to message #1703940] |
Thu, 06 August 2015 01:02   |
See https://github.com/mbarbero/fr.obeo.releng.targetplatform/issues/59
I look forward to working with both of these timesaveing features,
John
>> thanks,
>> John
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
FUDForum. Page generated in 0.02475 seconds
