Home » Modeling » EMF » how to design a drag and drop between to containment references(EMF.Edit)
how to design a drag and drop between to containment references [message #1703881] Wed, 05 August 2015 15:03 Go to next message
voiry laurent is currently offline voiry laurentFriend
Can someone help me to desgin a drag and drop between two containment references shared by the same container ?
I want two design this DND between two views : each is displaying one of the two references.
I've tried to use for the target view an EditingDomainDropAdapter with generated item providers. But it is considering the two references as children features for the dragged element and the drop can then be done in the wrong reference.
I've also tried to override generated item providers two only consider the reference viewed in the target view. But in this case the drag and drop command cannot execute because no parent is found for the dragged element.
I've considered too put the item providers adapter factory of the source view in the dragged data, and design an EditingDomainDropAdatper using this factory for building the drag part of the drag an drop command. But it seems to be a big a job...
So I prefer to ask your help to find the wright design for my need.
Laurent
Re: how to design a drag and drop between to containment references [message #1703947 is a reply to message #1703881] Thu, 06 August 2015 04:36 Go to previous messageGo to next message
On 05/08/2015 8:44 PM, voiry laurent wrote:
> Hello,
How did you achieve that result? By modifying the item provider's
getChildrenFeatures(Object)?
Yes,
org.eclipse.emf.edit.provider.ItemProviderAdapter.getChildFeature(Object, Object)
does that. That's why I ask how you specialized it to show only one of
the features, because if you did it by specializing what's returned by
getChildrenFeatures it should only consider the one reference, and not
both...
> element.
I'm not sure specifically what you did, but getChildFeature should
return your desired target feature...
Seems not necessary. I imagine each view has its own specialized item
provider, each returning the desired feature for getChildrenFeatures,
and that all else should just work as a result.
> Best regards,
> Laurent
Re: how to design a drag and drop between to containment references [message #1703993 is a reply to message #1703947] Thu, 06 August 2015 12:55 Go to previous messageGo to next message
Hi Ed,
Thank for your prompt reply.
For displaying the desired reference in each view, I've indeed redefined each itemProvider's getChildrenFeatures(Object) to return the desired feature.
But I cannot use the same itemProviders in the editingDomains provided to their editingDomainViewerDropAdapters. The drop adapter is indeed using the same editingDomain to execute the drag or drop command. But with the redefined itemProvider, the drag cannot execute. As far as I remember, but I'm not sure, it is because no feature where to remove the dragged element is found.
Laurent
Re: how to design a drag and drop between to containment references [message #1704182 is a reply to message #1703993] Sat, 08 August 2015 07:20 Go to previous messageGo to next message
Laurent,
Comments below.
On 06/08/2015 2:55 PM, voiry laurent wrote:
> Hi Ed,
Yes, I see what you mean.
Specializing
org.eclipse.emf.edit.provider.ItemProviderAdapter.factorRemoveCommand(EditingDomain,
CommandParameter) so that it can still compute the feature from which to
remove seems necessary...
> Regards,
> Laurent
Re: how to design a drag and drop between to containment references [message #1705470 is a reply to message #1704182] Sun, 16 August 2015 11:34 Go to previous message
Thanks Ed,
I will test this solution and give you feedback as soon as possible.
Laurent
Previous Topic:[CDO] DBStore and Model Evolution
Next Topic:[CDO] Unmonitored fail-over example
Current Time: Sat May 30 15:56:37 GMT 2020
Powered by FUDForum. Page generated in 0.02285 seconds
