Home » Eclipse Projects » Target Management » RSE - Remote System Explorer - Change known_hosts path
icon4.gif  RSE - Remote System Explorer - Change known_hosts path [message #1703676] Tue, 04 August 2015 08:09 Go to next message
Michele Bassanini is currently offline Michele BassaniniFriend
i have reinstalled windows and copied the old workspace so i have the new Eclipse Mars ready to work.
I have changed partitions on hard disk so when I try to connect to a server via RSE it gives me the followin error:
---E:\Connessioni remote\known_hosts does not exist.
---Are you sure you want to create it?
Beacuse the E isn't there anymore and also it can't create the file.
Where I can change this path? there is some file where is stored?
I have tried to "find in files" with notepad++ searching both in workspace folder and eclipse folder but I haven't find anything.
I can't work... Sad
Michele
Re: RSE - Remote System Explorer - Change known_hosts path [message #1704098 is a reply to message #1703676] Fri, 07 August 2015 10:21 Go to previous message
Martin Oberhuber is currently offline Martin OberhuberFriend
The "known_hosts" file is usually used by SSH.
Check your Preferences > General > Network Connections > SSH2 > SSH2 Home
If this doesn't help you can also File > Export Preferences > All, then use a text editor to search for "E:" . Or you check your environment variables such as %HOME% .
Previous Topic:Eclipse Juno Crashes on Centos Environment
Next Topic:no ssh/ftp when using RSE
Current Time: Sun Dec 04 23:09:51 GMT 2022
Powered by FUDForum. Page generated in 0.02033 seconds
