Home » Eclipse Projects » WindowBuilder » Internal error(Windows Builder Design window crashes - java.lang.NullPointerException)
Internal error [message #1703503] Sat, 01 August 2015 16:33 Go to next message
Jerry Sowell is currently offline Jerry SowellFriend
WindowBuilder encountered unexpected internal error.
This could be caused by a WindowBuilder bug or by a misconfiguration issue, conflict, partial update, etc.
java.lang.Error: new JMenu("File")
Show stack trace.
Hide stack trace.
Stack trace:
Full context stack trace:
at org.eclipse.wb.core.eval.AstEvaluationEngine.evaluate(AstEvaluationEngine.java:71)
at org.eclipse.wb.internal.core.model.JavaInfoEvaluationHelper.evaluateExpression(JavaInfoEvaluationHelper.java:630)
at org.eclipse.wb.internal.core.model.JavaInfoEvaluationHelper.evaluate(JavaInfoEvaluationHelper.java:502)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.evaluateNode(JavaInfoParser.java:1309)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.access$1(JavaInfoParser.java:1300)
at org.eclipse.wb.internal.core.parser.JavaInfoParser$ExecutionFlowParseVisitor$3.run(JavaInfoParser.java:602)
at org.eclipse.wb.internal.core.utils.execution.ExecutionUtils.runRethrow(ExecutionUtils.java:119)
at org.eclipse.wb.internal.core.parser.JavaInfoParser$ExecutionFlowParseVisitor.postVisit(JavaInfoParser.java:592)
at sun.reflect.GeneratedMethodAccessor38.invoke(Unknown Source)
at org.eclipse.wb.core.eval.ExecutionFlowUtils$1.intercept(ExecutionFlowUtils.java:399)
at org.eclipse.jdt.core.dom.ASTVisitor$$EnhancerByCGLIB$$b4ee1941.postVisit(<generated>)
at org.eclipse.jdt.core.dom.ASTNode.accept(ASTNode.java:2714)
at org.eclipse.jdt.core.dom.ASTNode.acceptChild(ASTNode.java:2759)
at org.eclipse.jdt.core.dom.VariableDeclarationFragment.accept0(VariableDeclarationFragment.java:263)
at org.eclipse.jdt.core.dom.ASTNode.accept(ASTNode.java:2711)
at org.eclipse.jdt.core.dom.ASTNode.acceptChildren(ASTNode.java:2782)
at org.eclipse.jdt.core.dom.VariableDeclarationStatement.accept0(VariableDeclarationStatement.java:267)
at org.eclipse.wb.core.eval.ExecutionFlowUtils.visitStatement0(ExecutionFlowUtils.java:354)
at org.eclipse.wb.core.eval.ExecutionFlowUtils.visitStatement(ExecutionFlowUtils.java:315)
at org.eclipse.wb.core.eval.ExecutionFlowUtils.visitStatement0(ExecutionFlowUtils.java:336)
at org.eclipse.wb.core.eval.ExecutionFlowUtils.visit(ExecutionFlowUtils.java:247)
at org.eclipse.wb.core.eval.ExecutionFlowUtils.access$1(ExecutionFlowUtils.java:235)
at org.eclipse.wb.core.eval.ExecutionFlowUtils$1.endVisit(ExecutionFlowUtils.java:442)
at org.eclipse.wb.core.eval.ExecutionFlowUtils$1.intercept(ExecutionFlowUtils.java:391)
at org.eclipse.jdt.core.dom.ASTVisitor$$EnhancerByCGLIB$$b4ee1941.endVisit(<generated>)
at org.eclipse.jdt.core.dom.MethodInvocation.accept0(MethodInvocation.java:241)
at org.eclipse.jdt.core.dom.ExpressionStatement.accept0(ExpressionStatement.java:145)
at org.eclipse.wb.core.eval.ExecutionFlowUtils.visit(ExecutionFlowUtils.java:228)
at org.eclipse.wb.core.eval.ExecutionFlowUtils$1.endVisit(ExecutionFlowUtils.java:421)
at org.eclipse.wb.core.eval.ExecutionFlowUtils$1.intercept(ExecutionFlowUtils.java:389)
at org.eclipse.jdt.core.dom.ClassInstanceCreation.accept0(ClassInstanceCreation.java:316)
at org.eclipse.jdt.core.dom.Block.accept0(Block.java:137)
at org.eclipse.jdt.core.dom.TryStatement.accept0(TryStatement.java:250)
at org.eclipse.jdt.core.dom.MethodDeclaration.accept0(MethodDeclaration.java:635)
at org.eclipse.jdt.core.dom.AnonymousClassDeclaration.accept0(AnonymousClassDeclaration.java:144)
at org.eclipse.jdt.core.dom.ClassInstanceCreation.accept0(ClassInstanceCreation.java:314)
at org.eclipse.jdt.core.dom.MethodInvocation.accept0(MethodInvocation.java:239)
at org.eclipse.wb.core.eval.ExecutionFlowUtils.visit(ExecutionFlowUtils.java:191)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.parseRootMethods(JavaInfoParser.java:312)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.parse(JavaInfoParser.java:268)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.access$9(JavaInfoParser.java:238)
at org.eclipse.wb.internal.core.parser.JavaInfoParser$1.runObject(JavaInfoParser.java:153)
at org.eclipse.wb.internal.core.parser.JavaInfoParser$1.runObject(JavaInfoParser.java:1)
at org.eclipse.wb.internal.core.utils.execution.ExecutionUtils.runDesignTime(ExecutionUtils.java:159)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.parse(JavaInfoParser.java:151)
at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF(DesignPage.java:534)
at org.eclipse.wb.internal.core.editor.DesignPage.access$9(DesignPage.java:522)
at org.eclipse.wb.internal.core.editor.DesignPage$8$1.run(DesignPage.java:449)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:187)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:156)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4734)
at org.eclipse.wb.internal.core.editor.DesignPage$8.run(DesignPage.java:446)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:466)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:374)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:527)
at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF_withProgress(DesignPage.java:465)
at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF(DesignPage.java:415)
at org.eclipse.wb.internal.core.editor.UndoManager.refreshDesignerEditor(UndoManager.java:381)
at org.eclipse.wb.internal.core.editor.UndoManager.activate(UndoManager.java:90)
at org.eclipse.wb.internal.core.editor.DesignPage.handleActiveState_True(DesignPage.java:263)
at org.eclipse.wb.internal.core.editor.DesignPage.handleActiveState(DesignPage.java:241)
at org.eclipse.wb.internal.core.editor.multi.DefaultMultiMode.showPage(DefaultMultiMode.java:125)
at org.eclipse.wb.internal.core.editor.multi.DefaultMultiMode$1.widgetSelected(DefaultMultiMode.java:63)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4353)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1061)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1085)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1070)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:782)
at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.java:3110)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:1794)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.java:283)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4172)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1151)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:636)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:135)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:382)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:236)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
Re: Internal error [message #1703932 is a reply to message #1703503] Wed, 05 August 2015 22:32 Go to previous message
Eric Clayberg is currently offline Eric ClaybergFriend
Any chance of seeing the complete stack trace? It ended right at the important part (the NPE). A test case that triggers this would also be good to see.
Previous Topic:Parse hand written code
Next Topic:Crashing WindowBuilder and I invisible structure in Eclipse Mars
Current Time: Thu Aug 13 15:18:34 GMT 2020
Powered by FUDForum. Page generated in 0.01810 seconds
