Home » Archived » Eclipse Process Manager (Stardust) » JBoss EAP 6.2 and UserService(JBoss EAP 6.2 and UserService)
JBoss EAP 6.2 and UserService [message #1703403] Fri, 31 July 2015 10:23 Go to next message
Ramakrishnan Krishnamurthy is currently offline Ramakrishnan KrishnamurthyFriend
I am using Stardust 2.1.1, JBoss EAP 6.2 and EJB3 in my EAR.
In my application code, I am making the following call:
workflowService = ServiceFactoryLocator.get(request).getWorkflowService();
I get a error (see attached stacktrace file).
The relevant lines from carnot.properties are
Web.ServiceFactory = org.eclipse.stardust.engine.api.ejb3.EjbEnvServiceFactory
Security.Authentication.Mode = principal
I appreciate any help or suggestions
-Ramakrishnan
  • Attachment: stacktrace
    (Size: 8.86KB, Downloaded 144 times)
Re: JBoss EAP 6.2 and UserService [message #1703625 is a reply to message #1703403] Mon, 03 August 2015 17:43 Go to previous messageGo to next message
Vikram Kodak is currently offline Vikram KodakFriend
Member
Hi Ramakrishnan,
When you say application code, you mean from the Client or still executing this from the engine context?.
Re: JBoss EAP 6.2 and UserService [message #1704013 is a reply to message #1703625] Thu, 06 August 2015 16:31 Go to previous message
Hello Vikram Kodak
I am not using the stardust portal as provided. The application (named xxx-bpm) is packaged as a jar inside ear archive. One of the many wars inside the ear is the"customised" stardust portal/client 2.1.1.
Hence, I presume "engine context" would be correct.
-Ramakrishnan
Previous Topic:Issues while working with SOAP web services (HTTPS)
Next Topic:Deployed models are cached during unit tests
Current Time: Wed Jan 20 06:48:45 GMT 2021
Powered by FUDForum. Page generated in 0.02218 seconds
