Home » Modeling » M2T (model-to-text transformation) » [XPAND2] Learning basic(need helps on a simple question)
[XPAND2] Learning basic [message #1703397] Fri, 31 July 2015 05:41 Go to next message
Hi!
I'm learning XPAND2 and I'm trying to do something...
I have a list of elements :
- string name
- double age
- string adress.
In a FOREACH loop, I would like to do something once, just ONCE even if I found the same type after, when the type is a string, once when it's a double. How should I do?
Now, I have something like this but I can't do nothing with it...
 «FOREACH str.member AS mbr-»
            «LET mbr.type.toString() AS type-»
            «LET "true" AS value_str-»                        <==== How can I use this variable? comparing and change value...
                              «IF type == "string"-»
                                     DO SOMETHING()
                               «ENDIF-»
                                «IF type == "double"-»
                                     DO SOMETHING2()
                               «ENDIF-»
             «ENDLET-»
             «ENDLET-»
«ENDFOREACH-»
I'm not sure that my problem is comprehensible but wel...
Edai.
Re: [XPAND2] Learning basic [message #1703570 is a reply to message #1703397] Mon, 03 August 2015 04:38 Go to previous message
You can create a Set and add the already processed types into it:
«LET {}.toSet() AS types»
   «IF !types.contains(type)»
     «types.add(type) -> ""»
            		DO ONCE
     «ENDIF»
«ENDLET»
The expression ->"" will suppress the output of the add operation result into the text.
Note that LET defines a final variable, you can't change the value. It is supposed to be used to evaluate (complex) statements once and cache the result within a block where the result is used multiple times (e.g. collect all fields that meet a certain criteria).
Previous Topic: [Acceleo] Undefined "Let" expression
Next Topic:how to delete a file using a template
Current Time: Sun Nov 09 15:32:23 EST 2025
Powered by FUDForum. Page generated in 0.09168 seconds
