implementing kura bundle that publishes MQTT messages [message #1703318] |
Thu, 30 July 2015 15:21 |
Sabrina anirbas Messages: 45 Registered: April 2015 |
Member |
I am trying to follow this tutorial to develop a bundle that is able to publish MQTT messages :
http://eclipse.github.io/kura/doc/heater_demo.html
but I can't see where it use the setCloudService() method
looking to the source code of the heater example (attached file), can't find where!
starting the bundle without this method causes a null pointure exception (see bellow).
Any idea how to use the cloudServices to publish MQTT messages?
I followed this tuto to configure the cloud client:
http://eclipse.github.io/kura/doc/cloud-configuration.html
Thanks in advance for your help!
Here is the exception:
!STACK 0
java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.eclipse.equinox.internal.ds.model.ServiceComponent.activate(ServiceComponent.java:235)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.activate(ServiceComponentProp.java:146)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(ServiceComponentProp.java:347)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:620)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:197)
at org.eclipse.equinox.internal.ds.Resolver.buildNewlySatisfied(Resolver.java:473)
at org.eclipse.equinox.internal.ds.Resolver.enableComponents(Resolver.java:217)
at org.eclipse.equinox.internal.ds.SCRManager.performWork(SCRManager.java:816)
at org.eclipse.equinox.internal.ds.SCRManager$QueuedJob.dispatch(SCRManager.java:783)
at org.eclipse.equinox.internal.ds.WorkThread.run(WorkThread.java:89)
at org.eclipse.equinox.internal.util.impl.tpt.threadpool.Executor.run(Executor.java:70)
Caused by: java.lang.NullPointerException
at org.eclipse.kura.binding.enocean.EnOcean.activate(EnOcean.java:72)
... 15 more
Root exception:
Notes:
I don't implement the ConfigurableComponent in my class, should I?
and in the activation method I set m_cloudClient to:
m_cloudClient = m_cloudService.newCloudClient(APP_ID);
the obove line is the one causing the exception
but no previous set to the m_cloudService just a variable declaration
Attachment: Heater.java
(Size: 8.63KB, Downloaded 144 times)
[Updated on: Fri, 31 July 2015 06:18] Report message to a moderator
FUDForum. Page generated in 0.05033 seconds
