Home » Modeling » EMF » emf does not resolve reference on load
emf does not resolve reference on load [message #1703201] Wed, 29 July 2015 10:21 Go to next message
Clemens Schneider is currently offline Clemens SchneiderFriend
I have a function where I try to load a m1gen-file and then to resolve the resourceSet to get the referenced ecore-file. After that the target of the instantiators should be available. But they aren't. The line
System.out.println("instantiator: " + instantiator.getTarget().getName());
produces every time null value for the name...
@Mojo(name = "generate")
public class GeneratorMojo extends AbstractMojo {
	@Parameter
	private File m1genFile;
	public void execute() throws MojoExecutionException {
		List<ClassInstantiator> instantiators = new ArrayList<ClassInstantiator>();
		List<Goal> goals = new ArrayList<Goal>();
		EPackage.Registry packReg = EPackage.Registry.INSTANCE;
		packReg.put(M1genPackage.eNS_URI, M1genPackage.eINSTANCE);
		Resource.Factory.Registry fReg = Resource.Factory.Registry.INSTANCE;
		Map<String, Object> m = fReg.getExtensionToFactoryMap();
		m.put("m1gen", new XMIResourceFactoryImpl());
		m.put("ecore", new XMIResourceFactoryImpl());
		ResourceSet resSetIn = new ResourceSetImpl();
		resSetIn.setPackageRegistry(packReg);
		resSetIn.setResourceFactoryRegistry(fReg);
		Resource resourceIn = resSetIn.getResource(URI.createURI("file:/" + m1genFile.toString()), true);
		try {
			resourceIn.load(m);
		} catch (IOException e1) {
			e1.printStackTrace();
		EcoreUtil.resolveAll(resSetIn);
		TreeIterator<EObject> instances = resourceIn.getAllContents();
		M1GenModel m1gen = (M1GenModel) instances.next();
		EPackageImpl ePackage = (EPackageImpl) m1gen.getRefers().get(0);
		EObject next = null;
		while (instances.hasNext()) {
			next = instances.next();
			if (next instanceof Goal) {
				goals.add((Goal) next);
			if (next instanceof ClassInstantiator) {
				instantiators.add((ClassInstantiator) next);
		for (ClassInstantiator instantiator : instantiators) {
Re: emf does not resolve reference on load [message #1703204 is a reply to message #1703201] Wed, 29 July 2015 10:43 Go to previous messageGo to next message
Clemens,
What value does m1genFile have? Is it an absolute path? Better use use
URI.createFileURI than what you did (because on Linux it will produce
file://path), assuming the path is absolute in the first place. You can
also try casting instantiator.getTarget() to InternalEObject so you can
inspect the eProxyURI of it.
On 29/07/2015 12:21 PM, Clemens Schneider wrote:
> Hello,
> I have a function where I try to load a m1gen-file and then to resolve the resourceSet to get the referenced ecore-file. After that the target of the instantiators should be available. But they aren't. The line System.out.println("instantiator: " + instantiator.getTarget().getName()); produces every time null value for the name...
> @Parameter
> try {
> resourceIn.load(m);
Re: emf does not resolve reference on load [message #1703205 is a reply to message #1703204] Wed, 29 July 2015 11:01 Go to previous message
Thank you! It works.
I changed it to:
Resource resourceIn = resSetIn.getResource(URI.createFileURI(m1genFile.toString()), true);
m1gen is:
<m1genFile>C:/Users/cschneid/Desktop/workspace-tdg/model/Company.m1gen</m1genFile>
[Updated on: Wed, 29 July 2015 11:03]
Report message to a moderator
Previous Topic:Are there any SoaML EMF implementations?
Next Topic:EcoreTools: multiple Ecore models in one project
Current Time: Fri Jul 03 13:35:35 GMT 2020
Powered by FUDForum. Page generated in 0.01739 seconds
