Home » Modeling » GMF (Graphical Modeling Framework) » Executable GMF diagrams(Executable GMF diagrams)
Executable GMF diagrams [message #1703015] Tue, 28 July 2015 04:05 Go to next message
Luis castro is currently offline Luis castroFriend
I need help about:
How, i can create an executable diagram using GMF?
Re: Executable GMF diagrams [message #1703150 is a reply to message #1703015] Tue, 28 July 2015 21:33 Go to previous messageGo to next message
Ángel Moreno is currently offline Ángel MorenoFriend
Hi Luis,
In the GMF Dashboard you have an option (a checkbox) to create an RCP version of the GMF Diagram that you want to create. A RCP is a Rich Client Platform... in other words... a simple desktop application of your GMF Diagram.
You have a small tutorial in this page:
https://wiki.eclipse.org/Graphical_Modeling_Framework/Tutorial/Part_4
Ángel M.
Researcher @ Kybele Research Group
Rey Juan Carlos University, Madrid, Spain
Re: Executable GMF diagrams [message #1703152 is a reply to message #1703150] Tue, 28 July 2015 22:48 Go to previous messageGo to next message
Hi Ángel,
Thanks for your answer. I checked the tutorial.
However, now my question is: how to able the execution of any procedure or expression when i select any element in the generated diagram.
I appreciate your collaboration,
Re: Executable GMF diagrams [message #1703191 is a reply to message #1703152] Wed, 29 July 2015 09:09 Go to previous message
Hi Luis,
Under my point of view, the best way to apply actions to an EditPart or group of EditPart's selected it's to use the Popup Menu of the GMF Diagram generated. In a last message I published the point of access to the Popup Menu of a GMF Diagram generated by the GMF Dashboard, here is the post. From this point, you have to study how to create classes that implements the IAction interface, how to add to this classes the behaviour that you want to implement and how to add this actions to Popup Menu as menu Items.
Here, you have a small code that allow you get the selected items of your diagram:
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage().getSelection()
I recommend you study how it's works the code of deleteAction declared in the DiagramEditorContextMenuProvider class, for example, or study how to create classes that extends the AbstractActionHandler class.
Ángel M.
[Updated on: Wed, 29 July 2015 09:28]
Report message to a moderator
Previous Topic:No palette icons after installing plugin into host
Next Topic:Dynamic Node Color Change
Current Time: Sun Jan 17 11:16:01 GMT 2021
Powered by FUDForum. Page generated in 0.01740 seconds
