Home » Eclipse Projects » P2 » Dead Lock on P2 Category Publisher
Dead Lock on P2 Category Publisher [message #1702886] Mon, 27 July 2015 08:51 Go to next message
Jeeeyul Lee is currently offline Jeeeyul LeeFriend
My build script for bash looks like this:
eclipse \
	-nosplash \
	-application org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher \
	-metadataRepository file:$PWD \
	-artifactRepository file:$PWD \
	-source $PWD \
	-publishArtifact \
	-compress
eclipse \
	-nosplash \
	-console -consolelog \
	-application org.eclipse.equinox.p2.publisher.CategoryPublisher \
	-categoryDefinition file:$PWD/category.xml \
	-categoryQualifier \
	-compress
First line publishes all plugins and features on current directory. It works well always.
Second line should have to publish categories. It worked with Luna before, But now it produces lock error(below) with Mars. May be there are other different environments.
osgi> Generating metadata for ..
Generation completed with success [0 seconds].
!SESSION 2015-07-27 17:44:21.943 -----------------------------------------------
eclipse.buildId=4.5.0.I20150603-2000
java.version=1.8.0_51
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=ko_KR
Framework arguments:  -product org.eclipse.epp.package.modeling.product -application org.eclipse.equinox.p2.publisher.CategoryPublisher -metadataRepository file:/Users/jeeeyul/Workspaces/jeeeyul@github.com/jeeeyul.github.io/beta-update -categoryDefinition file:/Users/jeeeyul/Workspaces/jeeeyul@github.com/jeeeyul.github.io/beta-update/category.xml -categoryQualifier -compress
Command-line arguments:  -os macosx -ws cocoa -arch x86_64 -product org.eclipse.epp.package.modeling.product -console -consolelog -application org.eclipse.equinox.p2.publisher.CategoryPublisher -metadataRepository file:/Users/jeeeyul/Workspaces/jeeeyul@github.com/jeeeyul.github.io/beta-update -categoryDefinition file:/Users/jeeeyul/Workspaces/jeeeyul@github.com/jeeeyul.github.io/beta-update/category.xml -categoryQualifier -compress
!ENTRY org.eclipse.equinox.ds 2 0 2015-07-27 17:44:34.404
!MESSAGE Getting a lock required more than 10000 ms. There might be a synchronization problem in this callstack or just the build/dispose process of some components took too long!
!STACK 0
java.lang.Exception: Debug stacktrace
	at org.eclipse.equinox.internal.ds.InstanceProcess.getLock(InstanceProcess.java:120)
	at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:560)
	at org.eclipse.equinox.internal.ds.ServiceReg.getService(ServiceReg.java:53)
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212)
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210)
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111)
	at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45)
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496)
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461)
	at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619)
	at org.eclipse.equinox.internal.p2.core.ProvisioningAgent.addingService(ProvisioningAgent.java:159)
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941)
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:1)
	at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)
	at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:183)
	at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:318)
	at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:261)
	at org.eclipse.equinox.internal.p2.core.ProvisioningAgent.getService(ProvisioningAgent.java:66)
	at org.eclipse.equinox.internal.p2.engine.ProfilePreferences.doSave(ProfilePreferences.java:120)
	at org.eclipse.equinox.internal.p2.engine.ProfilePreferences$SaveJob.run(ProfilePreferences.java:49)
Strange thing is the second line works sometimes, but the problem is highly reproducible.
The script running under the:
  • OSX Yosemite
  • JDK 1.8.0_51
Am I missing something?
Re: Dead Lock on P2 Category Publisher [message #1702887 is a reply to message #1702886] Mon, 27 July 2015 08:52 Go to previous messageGo to next message
Pascal Rapicault is currently offline Pascal RapicaultFriend
Please open a bug report against p2 with the same details: https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Equinox
Re: Dead Lock on P2 Category Publisher [message #1702888 is a reply to message #1702887] Mon, 27 July 2015 08:54 Go to previous message
Are you sure that is this a bug?
Previous Topic:Install New Software shows error dialog when clicked.
Next Topic:Restart eclipse from touchpoint action
Current Time: Tue Oct 22 18:32:55 GMT 2019
Powered by FUDForum. Page generated in 0.02910 seconds
