Re: CVS repository [message #1702536 is a reply to message #1702521] |
Wed, 22 July 2015 23:56 |
On 07/22/2015 05:12 PM, sai bala wrote:
> I am trying to use P2 install in my RCP application in Eclipse Helios.
> But when i trying to connect to CVS repository
> ":pserver:mailto:anonymous@xxxxxxxxe.org:/cvsroot/rt" throws me an
> error saying Repository is not available. After that came to know CVS is
> not in use now and replaced by GIT.
> If thats the case how to use P2 install in my RCP application thru this
> GIT? any document available to refer the steps? Your help is much
> appreciated.
When I used Helios, the Git integration didn't work (as I recall). I
prefer Git and so used Git * * outside of Eclipse * *, which worked fine.
An option (still in Helios) that spans between CVS and Git is
Subversion, in the form of subclipse or subversive. This worked for me
also in my time prior to preferring Git.
Hope this helps.
Re: CVS repository [message #1702641 is a reply to message #1702637] |
Thu, 23 July 2015 16:57 |
On 07/23/2015 10:39 AM, sai bala wrote:
> Thanks. Any specific steps to get the Git view ? Also is there any
> separate process is required to create connection in Git, where can i
> find more details on this?
Here's what I can tell you...
1. Install git on your host, apt-get install git, etc. (yes, you can
find it for Windows, but I'm not a Windows guy, Google is your friend
there).
2. You said Helios. I would NOT use the eGit plug-in on that version,
but I think it was available. If you want to use eGit, please ask
questions in the Eclipse eGit forum.
3. Sign up at Bitbucket.org. They'll provide you with free space for any
projects you want and their on-site doc is pretty good. It's a great
hosting site and you can even share with up to 4 other guys before
paying. GitHub is also amazing, but, unless you're willing to pay, your
stuff is public.
4. I took notes back when I started using Git including on Eclipse
projects. These are here, your mileage may vary:
http://www.javahotchocolate.com/tutorials/git-lifecycle.html
I don't, however, advise you to stay on Helios. It was a really great
Eclipse version, but you should move ahead already. Asking questions
about Helios particulars may not always bring the quickest and most
generous responses from the forums. I'm not an RCP guy, but I think that
you'll get a lot more help with RCP if you keep up with the latest
Eclipse versions.
And come back here with Eclipse questions!
Cheers.
Russ
FUDForum. Page generated in 0.08621 seconds
