Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] possible bug: object references an unsaved transient instance
[Teneo] possible bug: object references an unsaved transient instance [message #1702340] Tue, 21 July 2015 15:48 Go to next message
Oleg Orlov is currently offline Oleg OrlovFriend
Hello all!
I have got this famous, but unexpected exception:
org.hibernate.TransientObjectException: object references an unsaved transient instance - save the transient instance before flushing: test.Embedded
My object model:
Emfatic:
class Embedded2 {
attr String[1] name;
class Embedded {
val Embedded2[1] value;
class Table {
val Embedded[*] content;
Now, persist root object Table, create Embedded and Embedded2, try to merge and got the exception, pointed above.
My setup:
hibernate:
<property name="hibernate.dialect">org.hibernate.dialect.PostgreSQL9Dialect</property>
<property name="hibernate.connection.driver_class">org.postgresql.Driver</property>
<property name="hibernate.connection.username">postgres</property>
<property name="hibernate.connection.password"></property>
<property name="hibernate.connection.url">jdbc:postgresql://192.168.2.75:5432/teneo</property>
<property name="hibernate.globally_quoted_identifiers">true</property>
<property name="default_entity_mode">dynamic-map</property>
teneo:
properties.put(PersistenceOptions.MAP_DOCUMENT_ROOT, "true");
properties.put(PersistenceOptions.AUTO_ADD_REFERENCED_EPACKAGES, "true");
properties.put(PersistenceOptions.MAXIMUM_SQL_NAME_LENGTH, "63");
properties.put(PersistenceOptions.SQL_NAME_ESCAPE_CHARACTER, "");
properties.put(PersistenceOptions.CASCADE_POLICY_ON_NON_CONTAINMENT, "REFRESH");
properties.put(PersistenceOptions.FORCE_LAZY, "true");
Generated mapping:
<class entity-name="test.Embedded2" abstract="false" lazy="true" discriminator-value="test.Embedded2" table="test_embedded2">
<meta attribute="eclassName" inherit="false">Embedded2</meta>
<meta attribute="epackage" inherit="false">test</meta>
<id type="long" name="e_id" column="e_id" access="org.eclipse.emf.teneo.hibernate.mapping.identifier.IdentifierPropertyHandler">
<meta attribute="syntheticId" inherit="false">true</meta>
<generator class="native"/>
</id>
<discriminator type="string">
<column name="dtype" index="test_embedded2dtype" length="255" not-null="true"/>
</discriminator>
<version name="e_version" column="e_version" access="org.eclipse.emf.teneo.hibernate.mapping.property.VersionPropertyHandler">
<meta attribute="syntheticVersion" inherit="false">true</meta>
</version>
<property name="name" lazy="false" insert="true" update="true" not-null="true" unique="false" type="java.lang.String">
<column not-null="true" unique="false" name="name"/>
</property>
</class>
<class entity-name="test.Embedded" abstract="false" lazy="true" discriminator-value="test.Embedded" table="test_embedded">
<meta attribute="eclassName" inherit="false">Embedded</meta>
</id>
<column name="dtype" index="test_embeddeddtype" length="255" not-null="true"/>
</discriminator>
</version>
</property>
<many-to-one name="value" entity-name="test.Embedded2" lazy="proxy" cascade="all" foreign-key="test_embedded_value" insert="true" update="true" not-null="true" unique="true">
<column not-null="true" unique="false" name="embedded2_value_e_id"/>
</many-to-one>
</class>
<class entity-name="test.Table" abstract="false" lazy="true" discriminator-value="test.Table" table="test_table">
<meta attribute="eclassName" inherit="false">Table</meta>
</id>
<column name="dtype" index="test_tabledtype" length="255" not-null="true"/>
</discriminator>
</version>
</property>
<list name="content" lazy="true" cascade="all,delete-orphan">
<key foreign-key="test_table_content_key" update="true">
<column name="table_content_e_id" unique="false"/>
</key>
<list-index column="table_content_idx"/>
<one-to-many entity-name="test.Embedded"/>
</list>
</class>
Any hints, please?
[Updated on: Tue, 21 July 2015 15:58]
Report message to a moderator
Re: [Teneo] possible bug: object references an unsaved transient instance [message #1702380 is a reply to message #1702340] Tue, 21 July 2015 22:30 Go to previous messageGo to next message
I made some investigations in the debugger to see, whats going on here.
1. Table object has its e_id, Embedded and Embedded2 are in transient state.
2. Merge Table object.
3. Hibernate cascade merge to Embedded and then to Embedded2.
4. Hibarnate trying propagate cascade merge back to Embedded and failed with exception.
Step 4 here is the root of the problem. Embedded2 references to Embedded with special, teneo specific, association EContainerUserType. Then hibernate ask this association about its direction (getForeignKeyDirection) it answers ForeignKeyDirection.FOREIGN_KEY_FROM_PARENT (this is not true in that case) and hibernate decide to propagate merge back to Embedded object.
If we intercept this process in the debugger and force to return from getForeignKeyDirection anything but FOREIGN_KEY_FROM_PARENT , merge process ends with success.
Re: [Teneo] possible bug: object references an unsaved transient instance [message #1702553 is a reply to message #1702380] Thu, 23 July 2015 07:59 Go to previous messageGo to next message
Martin Taal is currently offline Martin TaalFriend
Hi Oleg,
Can you enter a bugzilla for it? It would be great if you can attach a small example model so there is no confusion on
this. If you can add some pseudo code which shows what you do to reproduce the issue then I can move that into a test case.
And also which teneo/hibernate version you are running/testing.
gr. Martin
> to Embedded object.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Teneo] possible bug: object references an unsaved transient instance [message #1702603 is a reply to message #1702553] Thu, 23 July 2015 13:26 Go to previous messageGo to next message
Hi Martin.
We use 2.1.0.v201505242010
Ill report to bugzilla as you suggested.
Re: [Teneo] possible bug: object references an unsaved transient instance [message #1702620 is a reply to message #1702603] Thu, 23 July 2015 14:44 Go to previous message
Done.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=473413
Ive attached small java code to reproduce my case.
Previous Topic:[Teneo] two small enhancements in SerializableDynamicEObjectImpl
Next Topic:Problem with installation of ecore diagramm
Current Time: Sat Jan 16 13:13:22 GMT 2021
Powered by FUDForum. Page generated in 0.01563 seconds
