Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Random Plugin Errors(Acceleo is throwing random erros about "The feature 'iff' is not a valid feature")
[Acceleo] Random Plugin Errors [message #1702246] Tue, 21 July 2015 01:46 Go to next message
Samuel Windall is currently offline Samuel WindallFriend
I am getting errors such as:
  • An internal error occurred during: "Acceleo".
  • Errors running builder 'Acceleo Builder' on project '<Acceleo Project Here>'.
  • Problems occurred when invoking code from plug-in: "org.eclipse.core.resources".
All with this exact stack trace:
java.lang.IllegalArgumentException: The feature 'iff' is not a valid feature
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eStructuralFeature(BasicEObjectImpl.java:733)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eObjectForURIFragmentSegment(BasicEObjectImpl.java:551)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObject(ResourceImpl.java:766)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObject(ResourceImpl.java:742)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setValueFromId(XMLHandler.java:2850)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setAttribValue(XMLHandler.java:2755)
at org.eclipse.emf.ecore.xmi.impl.SAXXMIHandler.handleObjectAttribs(SAXXMIHandler.java:79)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFactory(XMLHandler.java:2229)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFeatureType(XMLHandler.java:2195)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHandler.java:2071)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.createObject(XMIHandler.java:128)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLHandler.java:1876)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1030)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMIHandler.java:81)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:1008)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:719)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHandler.java:163)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:261)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1297)
at org.eclipse.acceleo.common.internal.utils.AcceleoPackageRegistry.registerEcorePackages(AcceleoPackageRegistry.java:309)
at org.eclipse.acceleo.internal.ide.ui.builders.AcceleoBuilder.build(AcceleoBuilder.java:154)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:734)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:206)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:246)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:299)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:302)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:263)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:401)
at org.eclipse.core.internal.resources.Project$1.run(Project.java:618)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2313)
at org.eclipse.core.internal.resources.Project.internalBuild(Project.java:597)
at org.eclipse.core.internal.resources.Project.build(Project.java:114)
at org.eclipse.debug.core.model.LaunchConfigurationDelegate$1.run(LaunchConfigurationDelegate.java:430)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2295)
at org.eclipse.debug.core.model.LaunchConfigurationDelegate.buildProjects(LaunchConfigurationDelegate.java:437)
at org.eclipse.debug.core.model.LaunchConfigurationDelegate.buildForLaunch(LaunchConfigurationDelegate.java:130)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:855)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:739)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:1039)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1256)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
It is happening when I, Try to make a new Acceleo Project, Try to open a *.mtl file, Try to build a project, or pretty much any other task to do with Acceleo.
It doesn't happen all the time, restarting eclipse seems to fix it for a bit, but once one error comes I have to restart if I want to work with Acceleo.
I have tried reinstalling Acceleo but it didn't fix it.
Any help would be much appreciated Smile
Re: [Acceleo] Random Plugin Errors [message #1702248 is a reply to message #1702246] Tue, 21 July 2015 04:29 Go to previous messageGo to next message
If "*iff", where * is a single letter makes sense as the name of a
feature, you have a problem that has been reported a few times before.
Solution, clean/rebuild/restart a few times. Make sure your Java
versions are consisten. Use ASCII rtaher than binary for your *.mtl files.
Ed Willink
> Here>'.
> Quote:
>> feature
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
> with Acceleo.
> Acceleo.
> Any help would be much appreciated :)
Re: [Acceleo] Random Plugin Errors [message #1702374 is a reply to message #1702248] Tue, 21 July 2015 21:33 Go to previous message
Thanks for the fast reply Smile
"*iff" would make sense for the name of a feature.
I have tried to clean/rebuild/restart a few times, As far as I can tell my Java
versions are consistent (1.7) everywhere I can see.
As for ASCII rather than binary for your *.mtl files. I was unsure about this, it was set to use XMI for *.mtl files and I changed the file encoding to ASCII if that is what you mean.
After all of this, I still cant do anything with Acceleo
Previous Topic:[Acceleo] Run my generator code from CLI
Next Topic: [Acceleo] Undefined "Let" expression
Current Time: Fri Oct 15 21:47:16 GMT 2021
Powered by FUDForum. Page generated in 0.01854 seconds
