Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Dynamic Template Plugin(I want to be able to generate with a Acceleo Template in the Workspace from a Eclipse Plugin I have made.)
[Acceleo] Dynamic Template Plugin [message #1702120] Mon, 20 July 2015 07:02 Go to next message
Samuel Windall is currently offline Samuel WindallFriend
I want to run an Acceleo Project from an Installed Plugin. i.e. I want to be able to generate with a Acceleo Template in the Workspace from a Eclipse Plugin I have made.
Currently, I have an Acceleo project which I run from my Eclipse Plugin programmatically:
try {
final File outputDir = new File("C:/outputDir/");
List<String> arguments = new ArrayList<String>();
/*fc is an instance of a EMF Compare Comparison object
 * the nsURI for it is http://www.eclipse.org/emf/compare
Generate generator = new Generate(fc, outputDir, arguments);
            generator.doGenerate(new BasicMonitor());
} catch (IOException e) {
e.printStackTrace();
The template is simple at the moment:
[comment encoding = UTF-8 /]
[module generate('http://www.eclipse.org/emf/compare')]
[template public generateElement(comparison : Comparison)]
[comment @main/]
[file ('update.sql', false, 'UTF-8')]
/*SQL UPDATE SCRIPT TEST*/
[comparison.getDifferences().toString() /]
[/file]
[/template]
This generates perfectly.
The issue is that I need to deploy the plugin but I still need end users to be able to modify the templates. The end goal is to have the Acceleo project in the end users' Workspace and let my plugin call it at runtime, but no matter how I set it up, I have to include the Acceleo project in my Plugin Feature.
Things I have attempted:
Overriding the Acceleo Module from a project in the end users workspace
Various attempts with java class loaders - I feel this is the way to go but I can't seem to get a working example
I am running:
Eclipse Luna SR2 (4.4.2)
Windows 7 Pro - 64bit - SP1
Acceleo 3.5.1.201409021433
JRE 1.8.0_45
Re: [Acceleo] Dynamic Template Plugin [message #1742927 is a reply to message #1702120] Thu, 08 September 2016 15:36 Go to previous message
pere joseph rodríguez is currently offline pere joseph rodríguezFriend
Member
have you tried to put a platform:/resource/workspaceproject/path... URI on the template path of the extension point? don't know if it would work....
Previous Topic:Best method for generating code from XSD
Next Topic:Unable to generate code
Current Time: Sat Feb 08 04:38:01 GMT 2025
Powered by FUDForum. Page generated in 0.03586 seconds
