Home » Newcomers » Newcomers » Eclipse JEE 4.5.0 (MARS)(How to install Eclipse JEE 4.5.0 (Need Install instructions))
Eclipse JEE 4.5.0 (MARS) [message #1701924] Thu, 16 July 2015 17:29 Go to next message
karthick Balaiah is currently offline karthick BalaiahFriend
I installed JDK 32 bit 1.7.0_60 on my machine and unzipped eclipse 4.5.0 mars to my C:\program files x(86). I get a error message when i rum the eclipse.exe.
Below is the error message:
version 1.60_95 of the jvm is not suitable for this product . version 1.7 or greater is required
I set the environment variable to point 32 bit JDK
Please help me out on this issue.
thanks,
Karthick.
Re: Eclipse JEE 4.5.0 (MARS) [message #1701932 is a reply to message #1701924] Thu, 16 July 2015 19:45 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
karthick Balaiah wrote on Thu, 16 July 2015 13:29
Which one? PATH? Have you tried pointing Eclipse at the correct java.exe using the command line -vm switch?
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Eclipse JEE 4.5.0 (MARS) [message #1701989 is a reply to message #1701932] Fri, 17 July 2015 09:42 Go to previous messageGo to next message
I created user variable PATH = C:\WINDOWS;C:\WINDOWS\system32;C:\Program Files (x86)\Java\jdk1.7.0_60\bin
System variable JAVA_HOME = C:\Program Files (x86)\Java\jdk1.7.0_60 and ran the executable file.
'Have you tried pointing Eclipse at the correct java.exe using the command line -vm switch?'
How to make -vm switch point the correct JVM?
Re: Eclipse JEE 4.5.0 (MARS) [message #1701998 is a reply to message #1701989] Fri, 17 July 2015 10:30 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Am 17.07.2015 um 11:42 schrieb karthick Balaiah:
The new Eclipse Installer would configure that automatically for you: http://wiki.eclipse.org/Eclipse_Installer
Cheers
/Eike
http://www.esc-net.de
Re: Eclipse JEE 4.5.0 (MARS) [message #1702019 is a reply to message #1701998] Fri, 17 July 2015 14:11 Go to previous messageGo to next message
I would like to understand the manual process.
Can you please help?
Re: Eclipse JEE 4.5.0 (MARS) [message #1702021 is a reply to message #1702019] Fri, 17 July 2015 15:13 Go to previous messageGo to next message
I need to completed this as soon as possible.
please help me out.
Re: Eclipse JEE 4.5.0 (MARS) [message #1702041 is a reply to message #1702021] Fri, 17 July 2015 20:29 Go to previous message
Eric Rizzo is currently offline Eric RizzoFriend
You should read all of the Announcement messages at the top of the Newcomers forum, specifically the one titled Eclipse won't start? READ THIS FIRST...
Previous Topic:Luna Project Explorer shows folder as unknown type
Next Topic:Phortran outline links don't work
Current Time: Tue Aug 04 05:47:44 GMT 2020
Powered by FUDForum. Page generated in 0.09169 seconds
