Home » Newcomers » Newcomers » Right-click problem(Right-clicking in Eclipse on Mac)
Right-click problem [message #1701651] Tue, 14 July 2015 16:54 Go to next message
Arthur Stewart is currently offline Arthur StewartFriend
I have just started learning Eclipse and I understand that to assign a Class I am to Right-Click on the SRC icon that's under the project name in Package Explorer to get the Java Class Wizard. Well Right-Clicking doesn't work. The only way I can access the Wizard is by using the Pull Down Menu that's at the left of the Package Explorer tab. I am using a Mac with 10.9.5. The Right-Click doesn't work on any of the other times I am told to use it. How to I contact someone to help me?
Thank you
Re: Right-click problem [message #1701657 is a reply to message #1701651] Tue, 14 July 2015 17:45 Go to previous messageGo to next message
Eric Rizzo is currently offline Eric RizzoFriend
Right-clicking is disabled by default in OS X (OS X instead wants you to use Ctrl+Click). You can enable it via System Preferences. See https://support.apple.com/kb/PH18768?locale=en_US for more details.
Re: Right-click problem [message #1701671 is a reply to message #1701657] Tue, 14 July 2015 20:03 Go to previous message
Thank you for the information.
Previous Topic:Issue building a synchronized project
Next Topic:Search and Replace a pattern in eclipse.
Current Time: Sun Sep 20 23:28:21 GMT 2020
Powered by FUDForum. Page generated in 0.03162 seconds
