Home » Modeling » TMF (Xtext) » Testing multiple Xtext Dsl's
Testing multiple Xtext Dsl's [message #1701469] Mon, 13 July 2015 14:44 Go to next message
Neeraj Bhusare is currently offline Neeraj BhusareFriend
I am trying to write unit-tests for a set of simple dsl's [0] - allows defining classes [1] and functions [2]. These languages reuse a set of common rules defined in a base language [3]. I have a hypothetical usecase [4] that I am trying to test.
I have read this article [5] on unit-testing multple dsl's. I have defined a test injector provider [6] that calls the injectior providers inject method for the the other dsl's.
The problem I am facing is that the corss-references are not getting resolved. To be specific, the Library cross reference in the funciton definition [7] is not getting resolved. I have made sure that all the resources are loaded in a single resource set. The test injector provider makes sure that the emf registery is initialized properly.
Am I missing something here ??? Would be great if I could get some help. Tx.
[0] https://github.com/nbhusare/xtext-tests
[1] https://github.com/nbhusare/xtext-tests/blob/master/org.neclipse.xtext.testing.smallJava/src/org/neclipse/xtext/testing/smallJava/SmallJavaDsl.xtext
[2] https://github.com/nbhusare/xtext-tests/blob/master/org.neclipse.xtext.testing.smallfunc/src/org/neclipse/xtext/testing/smallfunc/SmallFuncDsl.xtext
[3] https://github.com/nbhusare/xtext-tests/blob/master/org.neclipse.xtext.testing.smallArtifact/src/org/neclipse/xtext/testing/smallArtifact/SmallArtifactDsl.xtext
[4] https://github.com/nbhusare/xtext-tests/blob/master/org.neclipse.xtext.testing.smallfunc/src/org/neclipse/xtext/testing/smallfunc/validation/SmallFuncDslValidator.xtend
[5] http://zarnekow.blogspot.in/2014/10/testing-multiple-xtext-dsls.html
[6] https://github.com/nbhusare/xtext-tests/blob/master/org.neclipse.xtext.testing.smallfunc.tests/src/org/neclipse/xtext/testing/smallfunc/tests/setup/SmallFuncDslTestInjectorProvider.xtend
[7] https://github.com/nbhusare/xtext-tests/blob/master/org.neclipse.xtext.testing.smallfunc.tests/src/org/neclipse/xtext/testing/smallfunc/tests/SmallFuncDslValidatorTest.xtend
Twitter : @NeerajBhusare
Blog : https://nbhusare.github.io/
Best regards, Neeraj
Re: Testing multiple Xtext Dsl's [message #1701490 is a reply to message #1701469] Mon, 13 July 2015 16:47 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
ParseHelper is not meant to be used in that usecase. you have to fix it to be able to handle it
@RunWith(XtextRunner)
@InjectWith(SmallFuncDslTestInjectorProvider)
class SmallFuncDslValidatorTest {
	@Inject extension SmartParseHelper<Namespace>
	@Inject extension ValidationTestHelper
	@Inject Provider<XtextResourceSet> resourceSetProvider
	@Test
	def void testCheckParamIfSmallClassHasAttributes() {
		val rs = resourceSetProvider.get
		val sc = '''
			namespace tests.smalllang
			class Library {
		'''.parse(rs,"sjava")
		val smallFunc = '''
			import tests.smalllang.*
			def CheckLibraryHasBooks(Library library) {
		'''.parse(rs).artifact as SmallFunction
		smallFunc.params.head => [
			assertError(SmallFuncDslPackage.Literals.PARAM, "", "Small class has no attributes...")
class SmartParseHelper<T extends EObject> extends ParseHelper<T> {
	@Inject
	IResourceFactory resourceFactory;
	def T parse(CharSequence text, ResourceSet resourceSetToUse, String fileExtension) throws Exception {
		return parse(getAsStream(text), computeUnusedUri(resourceSetToUse, fileExtension), null, resourceSetToUse, fileExtension) as T
	def URI computeUnusedUri(ResourceSet resourceSet, String fileExtension) {
		val String name = "__synthetic";
		for (i : 0..Integer.MAX_VALUE) {
			val URI syntheticUri = URI.createURI(name + i + "." + fileExtension);
			if (resourceSet.getResource(syntheticUri, false) == null)
				return syntheticUri;
		throw new IllegalStateException();
	def T parse(InputStream in, URI uriToUse, Map<?, ?> options, ResourceSet resourceSet, String fileExtension) {
		val Resource resource = resourceSet.createResource(uriToUse);
		try {
			resource.load(in, options);
			val T root = if (resource.getContents().isEmpty()) null else resource.getContents().get(0) as T;
			return root;
		} catch (IOException e) {
			throw new WrappedException(e);
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
Re: Testing multiple Xtext Dsl's [message #1702028 is a reply to message #1701490] Fri, 17 July 2015 16:23 Go to previous message
Thanks. It helped Smile
Previous Topic:Unable to generate separate project in SimpleProjectWizardFragment
Next Topic:Serialising Xcore model to Xtext
Current Time: Thu Apr 25 21:31:37 GMT 2024
Powered by FUDForum. Page generated in 0.02678 seconds
