Home » Eclipse Projects » Vorto » Relation to OPC UA Information Model
Relation to OPC UA Information Model [message #1701282] Fri, 10 July 2015 13:09 Go to next message
Andreas Benzing is currently offline Andreas BenzingFriend
How is Vorto related to the OPC UA Information Model (see below)? Is there any connection at all?
opcfoundation.org/developer-tools/specifications-unified-architecture/part-5-information-model/
Re: Relation to OPC UA Information Model [message #1701298 is a reply to message #1701282] Fri, 10 July 2015 16:15 Go to previous messageGo to next message
Olaf Weinmann is currently offline Olaf WeinmannFriend
Hello Andreas,
There is definitely a relation! The OPC UA Information Model is part of the OPC Unified Architecture and allows amongst others the description of devices by specifying the structure of related nodes. These nodes can describe attributes, methods, and also events. There exist various other approaches and standards that also specify how devices can be represented. It is not in scope of the Vorto project to define a new, additional standard. The goal of Vorto is amongst others to create a tool that allows to transform the Vorto device descriptions (Information Models) into various formats using specific code generators. For example it shall be possible to create a code generator that transforms Vorto Information Models into OPC UA conform representations. But for example it also should be possible to transform Vorto Information Models into a HGi SDT conform representation by creating a corresponding code generator. For being able to do that for various standards the Vorto Meta model must be very flexible und thus is the most important component of the project. Another requirement for the Vorto Information Models is, that they have to be human readable and that they have a structure which is easy to understand.
Does that answer your question?
Re: Relation to OPC UA Information Model [message #1701299 is a reply to message #1701298] Fri, 10 July 2015 16:37 Go to previous message
Hi Olaf,
thanks for the explanation. That was exactly the information I was looking for Very Happy
I'm looking forward to seeing Vorto evolve!
[Updated on: Fri, 10 July 2015 16:37]
Report message to a moderator
Previous Topic:Modeling Industrie 4.0 / Connected Industries
Next Topic:Mapping Vorto Model to Target Domain models
Current Time: Mon Mar 08 00:59:11 GMT 2021
Powered by FUDForum. Page generated in 0.02036 seconds
