Necessary plugins for Sirius [message #1701189] |
Thu, 09 July 2015 14:24  |
I just started with Sirius and wonder which plugins are necessary to run a viewpointspec. I modeled my meta model with Xcore. Out of this, I generated then an ecore and genmodel, while the .edit plugin is already provided by Xcore. Does Sirius also depend on the .editor plugin?
Within the Viewpontspec I was able to ref elements form the ecore so far.
Phil
Re: Necessary plugins for Sirius [message #1701722 is a reply to message #1701455] |
Wed, 15 July 2015 05:07  |
Le 13/07/2015 16:03, Phil Hei a écrit :
> Laurent Redor wrote on Fri, 10 July 2015 09:26
>> Le 09/07/2015 The ".edit" project is better to have "beautiful" icons.
>> The ".editor" project allow you to create easily an new model.
>> But this 2 last projects are not strictly necessary for Sirius.
> Thx for the quick response!
> - What do you mean with ""beautiful" icons"? Do you have an example from
> the editor? Where will the icons be used? Within the Tool Palette and
> Treeview?
In the .edit you have generated default icons. You can replace them by
your own "beautiful icons" and they will be used pretty much everywhere,
palette, editors, properties view.
> - And what is meant by "create easily a new model"? I thought when I
> change my metamodel, I'll create a new model?
The .editor provides generated wizards and a default editor to manage
your model.
Note that this is not Sirius fonctionalities but EMF[1] ones.
Steve
[1] https://eclipse.org/modeling/emf/
> Cheers,
> Phil
Steve Monnier - Obeo
Need professional services for Sirius?
FUDForum. Page generated in 0.09367 seconds
