Home » Modeling » EMF » I don't understand TransactionalEditingDomain.runExclusive
I don't understand TransactionalEditingDomain.runExclusive [message #1701110] Thu, 09 July 2015 11:54 Go to next message
Nils Ruhr is currently offline Nils RuhrFriend
Hi.
Reading the documentation of runExclusive I thought when two runnables from different threads access the editing domain they both run exclusively. However this seems not to be the case.
If I run the following code I get the output:
t1: Running exclusive start
t2: Running exclusive start
t2: Running exclusive end
t1: Running exclusive end
What am I doing wrong?
Code:
EClass model = EcoreFactory.eINSTANCE.createEClass();
ResourceSet resourceSet = new ResourceSetImpl();
Resource resource = new ResourceImpl();
resource.setURI(URI.createURI("synthetic://model"));
resourceSet.getResources().add(resource);
resource.getContents().add(model);
TransactionalEditingDomain.Factory.INSTANCE.createEditingDomain(resourceSet);
TransactionalEditingDomain domain = TransactionUtil.getEditingDomain(model);
Thread t1 = new Thread(() -> {
    try {
        TransactionUtil.getEditingDomain(model).runExclusive(() -> {
            System.out.println((Thread.currentThread().getName() + ": Running exclusive start"));
            try {
                Thread.sleep(2000l);
            } catch (Exception e) {
                e.printStackTrace();
            System.out.println(Thread.currentThread().getName() + ": Running exclusive end");
t1.setName("t1");
Thread t2 = new Thread(() -> {
    try {
        domain.runExclusive(() -> {
            System.out.println(Thread.currentThread().getName() + ": Running exclusive start");
t2.setName("t2");
t1.start();
Thread.sleep(1000);
t2.start();
t1.join();
t2.join();
Re: I don't understand TransactionalEditingDomain.runExclusive [message #1701121 is a reply to message #1701110] Thu, 09 July 2015 13:07 Go to previous messageGo to next message
Christian Damus is currently offline Christian DamusFriend
Are you running this code in a running Eclipse instance, with the Job
Manager enabled (not in its suspended state)? The transaction lock is
implemented using the Job Manager's locking system, which supports
deadlock detection.
Christian
On 2015-07-09 11:54:24 +0000, Nils Ruhr said:
> Hi.
> Code:
> try {
> try {
> t1.setName("t1");
> try {
> t2.setName("t2");
> t1.start();
> Thread.sleep(1000);
> t2.start();
> t1.join();
> t2.join();
Re: I don't understand TransactionalEditingDomain.runExclusive [message #1701147 is a reply to message #1701121] Thu, 09 July 2015 14:09 Go to previous message
I see. No, I was running it as a simple JUnit test. Indeed executing the code in a running Eclipse instance I get:
Previous Topic:How to extends the copy/paste command ?
Next Topic:[CDO] Finding commits matching specific predicate
Current Time: Wed Sep 23 12:45:46 GMT 2020
Powered by FUDForum. Page generated in 0.02288 seconds
