Home » Eclipse Projects » Nebula » Nebula grid GridItem.setForeground(color) not working
Nebula grid GridItem.setForeground(color) not working [message #1700884] Tue, 07 July 2015 20:54 Go to next message
Dhiresh Patel  is currently offline Dhiresh Patel Friend
Member
I am using GridTableViewer and Nebula Grid.
I am in processing of replacing old grid with new grid
version = org.eclipse.nebula.widgets.grid_1.0.0.201506030727.
I am setting individual row's foreground color.
for ( int i=0; i < items.length; i++){
items[i].setForeground(color); ;
The above code worked with old grid version ver = 1.0.0.201209220511
However it's not working with new version. What do I need to change?
Dhiresh
Re: Nebula grid GridItem.setForeground(color) not working [message #1700891 is a reply to message #1700884] Tue, 07 July 2015 22:53 Go to previous messageGo to next message
Member
I have grid.setCellSelectionEnabled(true);
What I found was that if I did GridItem.setForeground(index, foreground); for
all the columns it works - meaning the whole row has that foreground color.
But GridItem.setForeground(foreground); does not work -
Has this been changed?
Dhiresh
Re: Nebula grid GridItem.setForeground(color) not working [message #1700922 is a reply to message #1700891] Wed, 08 July 2015 08:19 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
If you are using a GridTableViewer why are you then calling out to the
SWT-API? It is the job of the LabelProvider to provide the foreground
color.
If you can reproduce this:
a) with a Grid only snippet (no JFace viewer)
b) with a GridTableViewer only snippet (no call to GridItem)
File a bug and we can take a look if this is a regression
Tom
> foreground); for
> But GridItem.setForeground(foreground); does not work - Has this been
> changed?
> Dhiresh
Re: Nebula grid GridItem.setForeground(color) not working [message #1708941 is a reply to message #1700922] Tue, 22 September 2015 15:55 Go to previous message
Member
This problem has been fixed.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=477643
Previous Topic:XYGraph - how to draw data points with no connecting line?
Next Topic:Copy feature inside Nebula Grid
Current Time: Thu Jul 02 09:12:09 GMT 2020
Powered by FUDForum. Page generated in 0.01842 seconds
