Home » Modeling » UML2 » UML 2.5 DI support
UML 2.5 DI support [message #1700693] Mon, 06 July 2015 13:48 Go to next message
Denis Nikiforov is currently offline Denis NikiforovFriend
Does Eclipse UML support diagram interchange? It seems that DI is a part of UML 2.5 specification. But I can't find UMLDiagram class and others in Eclipse UML.
Do you plan to implement them?
I guess that Papyrus implement UML 2.5 DI. Is it possible to use DI metamodel in our project. We don't need Papyrus editing finctionality. We need only to parse/serialize UML 2.5 DI. Is it possible somehow?
Thanks!
Re: UML 2.5 DI support [message #1700695 is a reply to message #1700693] Mon, 06 July 2015 13:54 Go to previous messageGo to next message
Camille Letavernier is currently offline Camille LetavernierFriend
Hi Denis,
UML DI is partially supported by Papyrus, as an extra-component. Papyrus also provides a feature to export Papyrus diagrams to UML DI
Eclipse/UML itself doesn't provide such support, but you can probably reuse the UMLDI Metamodel from Papyrus (Although we don't consider it stable yet, I believe it's good enough and shouldn't change "too much", if at all)
It is not released as part of the main Papyrus project, but can be installed from this update site: http://download.eclipse.org/modeling/mdt/papyrus/updates/releases/mars/extra
HTH,
Camille
Camille Letavernier
Re: UML 2.5 DI support [message #1700701 is a reply to message #1700695] Mon, 06 July 2015 14:31 Go to previous message
Thanks a lot! Smile
Previous Topic:Importing IFML metamodel and profile
Next Topic:[Searching] for UML-Lib to draw an Component diagram
Current Time: Thu Aug 11 04:41:50 GMT 2022
Powered by FUDForum. Page generated in 0.02342 seconds
