Re: [EMF Forms] Null Pointer Exception on Custom View [message #1700817 is a reply to message #1700528] |
Tue, 07 July 2015 11:55 |
Looking at the stracktrace I think that no viewmodel could be found/created for Units.
Could you check if the org.eclipse.emf.ecp.view.model.provider.generator bundle is included in the run configuration? This provider will generate a default view model.
If you have modelled the view, make sure that the org.eclipse.emf.ecp.view.model.provider.xmi bundle is part of the run config and that you are registering the view at the org.eclipse.emf.ecp.view.model.provider.xmi.file extension point.
I hope this will solve the problem. Otherwise I would need a running demo including target definition.
Best regards
Johannes
Johannes Faltermeier
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
FUDForum. Page generated in 0.03355 seconds
