Home » Eclipse Projects » RCP Testing Tool » RCPTT with e4Application
RCPTT with e4Application [message #1700319] Wed, 01 July 2015 18:51 Go to next message
Connor Hitt is currently offline Connor HittFriend
I have been dealing with the issue of RCPTT not recognizing when my AUT had launched. I was able to fix this issue by creating an Application class and switching the "Application" field in the product configuration to this new class, essentially running my product as an e3 application.
However, when I change the field back to an "org.eclipse.e4.ui.workbench.swt.E4Application" as needed to properly run my program, I get the same start up error as before, which leads me to believe the issue is with e4applications. I was under the impression that RCPTT supported e4 applications since it was listed with the Mars release, but it's looking like it doesn't.
So my question is, does RCPTT support e4applications? And if so, what do I need to do to get it to work with them?
Re: RCPTT with e4Application [message #1700350 is a reply to message #1700319] Thu, 02 July 2015 06:22 Go to previous messageGo to next message
Ulyana Skorokhodova is currently offline Ulyana SkorokhodovaFriend
Hi Connor,
Unfortunately, RCPTT does not support E4 yet (unless there is a E3-E4 compatibility layer).
Work under E4 support is in active phase right now.
Kind regards,
Ulyana.
Re: RCPTT with e4Application [message #1700369 is a reply to message #1700350] Thu, 02 July 2015 08:07 Go to previous messageGo to next message
What do you mean by an E3-E4 compatability layer? How do I set this up?
Also, is there any estimate as to when E4 will be supported?
Re: RCPTT with e4Application [message #1709574 is a reply to message #1700369] Tue, 29 September 2015 10:45 Go to previous messageGo to next message
Hi Connor,
Here are the details about compatibility layer: http://eclipsesource.com/blogs/2012/06/18/migrating-from-eclipse-3-x-to-eclipse-4-e4/
E4 support task is scheduled on RCPTT 2.1.0 (Neon) Release, please track the activity here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=441067
Kind regards,
Ulyana.
Re: RCPTT with e4Application [message #1796724 is a reply to message #1709574] Thu, 18 October 2018 07:27 Go to previous message
Markus Manck is currently offline Markus ManckFriend
Member
although this thread is quite old, the problem persists.
Is there a schedule as to when pure E4 applications will be supported?
As a workaround the compatibility layer is mentioned, is there an example how to integrate it in a pure E4 application in such a way that RCPTT is able to test it?
The approach of integration of the compatibility layer as shown in various migration examples and tutorials did not yet work for me as the RCPTT could not successfully connect to the started AUT.
Has anyone done this successfully?
[Updated on: Thu, 18 October 2018 13:11]
Report message to a moderator
Previous Topic:Excel import and export example
Next Topic:How to add Environment variable for AUT
Current Time: Sat Dec 14 17:26:26 GMT 2024
Powered by FUDForum. Page generated in 0.03673 seconds
