Home » Eclipse Projects » Sirius » Custom properties Editor with EEF
Custom properties Editor with EEF [message #1700207] Tue, 30 June 2015 13:49 Go to next message
I need a custom properties editor for my Sirius diagram. This should be possible using EEF.
I'm using Eclipse Kepler with Sirius 2 and I'm doing everything exactly as described here: https://www.eclipse.org/sirius/doc/viewpoint-eef.html but the EEF properties editor is not visualized, I see again the standart properties editor. What am I doing wrong? I've also installed EEF Integration for Sirius, EEF Integration for Sirius Developer Resources, EEF Runtime, EEF Development Tools. I don't understand what's wrong. When I set value of the Leaf Components Super Class to org.eclipse.sirius.eef.components.SiriusAwarePropertiesEditingComponent, there is a compilation error because the class SiriusAwarePropertiesEditingComponent is unknown. Any suggestions?
Re: Custom properties Editor with EEF [message #1700240 is a reply to message #1700207] Wed, 01 July 2015 03:09 Go to previous messageGo to next message
Le 30/06/2015 19:49, qwer qwer a écrit :
> possible using EEF.
This the main doc entry for Sirius 3.0.0, which was recently released
with Mars and whose the minimum supported EEF version is EEF 1.5.
If you are still using Sirius 2.0.x and EEF 1.2, please look for the
corresponding documentation in
https://www.eclipse.org/sirius/doc/2.0.x/viewpoint-eef.html
Which version of EEF Runtime and Development tools do you have ?
SiriusAwarePropertiesEditingComponent has been introduced for Sirius
3.0.0 / EEF 1.5 (See Bug 436833 [2])
Maxime - Obeo
Need professional services for Sirius?
[1] https://www.eclipse.org/sirius/doc/2.0.x/viewpoint-eef.html
[2] https://bugs.eclipse.org/bugs/show_bug.cgi?id=436833
Re: Custom properties Editor with EEF [message #1700487 is a reply to message #1700240] Thu, 02 July 2015 17:37 Go to previous messageGo to next message
thank you! It works with Eclipse Mars, Sirius 3.0.0 and EEF 1.5. I can see the EEF property tabs. Now I have another probem: the data from my model file is not loaded properly. When I click on (1) a dialog with a list of elements should appear and the user should be able to chooce elements from this list but the list is always empty and I don't understand why. I tried with all widgets - combo, table ... and all variations but it doesn't work. The list is loaded properly in the standard semantic property tab. How should I solve this problem? And this problem appears everywhere a list of elements should be shown.
http://dl.dropboxusercontent.com/u/51877953/1.PNG
http://dl.dropboxusercontent.com/u/51877953/2.PNG
[Updated on: Sun, 05 July 2015 11:27] by Moderator
Re: Custom properties Editor with EEF [message #1700616 is a reply to message #1700487] Sun, 05 July 2015 11:23 Go to previous message
So the problem is that EEF generates me the GUI code and I have to implement the data binding and I don't have any idea how. For my meta modell component MyObject, I have a EMFComboViewer. In this EMFComboViewer a list of all created objects in the model of type AnotherObject has to be vizualized and the user has to be able to choose one of them. In the generated class MyObjectPropertiesEditionPartImpl I have the method createAnotherObjectEMFComboViewer(Composite parent) where the EMFComboViewer is created, the content provider is an ArrayContentProvider and here I have to set the Content of the EMFComboViewer in this way: comboViewer.setInput(input); When I create a list of AnotherObject manually and set it as Input for the EMFComboViewer, the list is visualized but there is a ClassCastException - AnotherObjectImpl cannot be cast to org.eclipse.emf.common.util.Enumerator - how should I solve this problem? And the biggest problem is: how to load the list of all created AnotherObject from the model (I don't have to create the list manually). Can you help me, please, it's urgent.
Previous Topic:Problem with copy and paste node in diagram
Next Topic:Using types from additional MetaModels
Current Time: Thu Jun 19 22:54:03 EDT 2025
Powered by FUDForum. Page generated in 0.04310 seconds
