Home » Modeling » Papyrus » Customizing UML Class Diagram(Can we customize graphical notation of uml class doagram in Papyrus ??!?!)
Customizing UML Class Diagram [message #1699860] Sat, 27 June 2015 16:03 Go to next message
Parsa Pourali is currently offline Parsa PouraliFriend
Hi Everyone,
I'm new to Papyrus, I was wondering if it is possible to add a compartment to a class in class diagram while creating a profile?
UML has two compartments for each class one is the attributes and one is the operations. now I need 3 or 4 compartments, attributes, Input operations, Output operations and IO operations. Is it possible?
Thanks.
Re: Customizing UML Class Diagram [message #1699909 is a reply to message #1699860] Mon, 29 June 2015 08:42 Go to previous messageGo to next message
Patrick Tessier is currently offline Patrick TessierFriend
In papyrus mars, it exists a mecanism in order to add compartment in diagram.
The documentation is under development.
Nevetheless, part of the document can be found in the git at this address: org.eclipse.papyrus\plugins\infra\gmfdiag\org.eclipse.papyrus.infra.gmfdiag.common\doc.
As soon as the documentations and the videos are ready , I will make a communication on this forum.
Re: Customizing UML Class Diagram [message #1699966 is a reply to message #1699909] Mon, 29 June 2015 13:41 Go to previous messageGo to next message
Thank you.
Is this Papyrus Mars the same as Papyrus? or it is a another product? I wanted to install it however not sure where to find the installation file.
Parsa
Re: Customizing UML Class Diagram [message #1700005 is a reply to message #1699966] Mon, 29 June 2015 15:27 Go to previous messageGo to next message
Camille Letavernier is currently offline Camille LetavernierFriend
"Mars" is the name of the latest Eclipse version (June 2015). "Papyrus Mars" is equivalent to "Papyrus 1.1", released last week
Eclipse 4.5 / Mars can be downloaded here: https://www.eclipse.org/downloads/
Then you can install Papyrus 1.1 on top of it
Camille
Camille Letavernier
Re: Customizing UML Class Diagram [message #1700008 is a reply to message #1700005] Mon, 29 June 2015 15:39 Go to previous message
O! I see, Thanks !
Previous Topic:Model Validation and Stereotypes
Next Topic:FlowPort Icons missing
Current Time: Mon Jun 01 00:16:24 GMT 2020
Powered by FUDForum. Page generated in 0.06710 seconds
