Home » Eclipse Projects » WindowBuilder » How can I install WindowBuilder for Eclipse Mars?
How can I install WindowBuilder for Eclipse Mars? [message #1699858] Sat, 27 June 2015 15:01 Go to next message
Bio Salk is currently offline Bio SalkFriend
Hi all,
I've Eclipse Mars (4.5.0) and I can't understand how install window builder.
I go to Help -> Install New Software... here I select:
Work with: Mars - http://download.eclipse.org/releases/mars
then I go to General Purpose Tools. The problem is that something missing.
I remember that with an older version of Eclipse I did the same steps and then I selected:
SWT Designer
SWT Designer Core
WindowBuilder Core
WindowBuilder Core UI
WindowBuilder GroupLayout Support
WindowBuilder Java Core
but with this new version there aren't this packages.
Someone can explain to me how I can install WindowBuilder? Thank you.
Re: How can I install WindowBuilder for Eclipse Mars? [message #1699950 is a reply to message #1699858] Mon, 29 June 2015 12:54 Go to previous message
Ok sorry, I resolved. I did some mistakes. I think is already installed but also with Help -> Install new software.. you can install it.
After I installed windowbuilder, it didn't work, so I installed openjdk (I'm on a Linux machine) and now everything work Smile
Previous Topic:WB Fails to render custom component with NoDefClassFoundException
Next Topic:Open dynamically JRadioButtons
Current Time: Tue Apr 16 15:46:28 GMT 2024
Powered by FUDForum. Page generated in 0.82799 seconds
