Home » Eclipse Projects » EPP » Confusing notification popup
Confusing notification popup [message #1699593] Thu, 25 June 2015 09:44 Go to next message
Jesper Eskilson is currently offline Jesper EskilsonFriend
The notification popup received when UI freezes are detected display a stacktrace which always seem to refer to the automatic error reporting code itself, and not to where the actual problem lies. See attached screenshot.
If it is not possible to show the stack trace of where the UI freeze occurs, it is better not to show a stack trace at all. Even as a fairly experienced Eclipse plugin developer, I was thrown off by this, and I suspect that other users will be confused as well.
IMHO, if these popups are intended for "normal" Eclipse users (as opposed to plugin developers), referring to plugin ids and stack traces in a notification such as this probably not a good idea.
Re: Confusing notification popup [message #1699674 is a reply to message #1699593] Thu, 25 June 2015 17:05 Go to previous messageGo to next message
Marcel Bruch is currently offline Marcel BruchFriend
I get your point. A simple improvement would be to just show the simple class name. Then it would not be *that* misleading. A special treatment for UI freezes, however, seems a bit like an overkill IMHO. But maybe a the discussion in bugzilla will change my mind... Smile
I created a bug [1] for tracking this request.
Thanks, Marcel
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=471033
Re: Confusing notification popup [message #1704908 is a reply to message #1699674] Mon, 10 August 2015 14:41 Go to previous message
FWIW: Starting from SR1, aeri will use shorter exception names in notification popups.
Previous Topic:[aeri] [poll] Should eclipse.org collect error reports for 3rd party plugin vendors?
Next Topic:[aeri] [ann] new milestone for Mars.1 ready for testing
Current Time: Thu Jul 02 15:31:25 GMT 2020
Powered by FUDForum. Page generated in 0.02352 seconds
