Home » Eclipse Projects » Oomph » Slicer mode for target platform?
Slicer mode for target platform? [message #1699537] Wed, 24 June 2015 20:26 Go to next message
Kai Kreuzer is currently offline Kai KreuzerFriend
I am using Oomph to define my target platform and also to generate my .target file through the TargetDefinitionGenerator.
Up to now, I manually maintained the .target file and I am using the "slicer" mode in it, i.e. it does not require all dependencies to be available. When generating the file through Oomph, it uses "planner" instead, which makes my resolution fail (because I include Jetty 9.2, which has dependencies that are not available in Orbit or an other p2 repo, see https://dev.eclipse.org/mhonarc/lists/jetty-users/msg04454.html).
Is there any way to make Oomph use the slicer mode as well?
Kai
Re: Slicer mode for target platform? [message #1699588 is a reply to message #1699537] Thu, 25 June 2015 09:18 Go to previous messageGo to next message
Kai,
No, there's nothing for that yet, but certainly we could add a bit more
annotation magic to specify that. Please open an enhancement request.
On 24/06/2015 10:26 PM, Kai Kreuzer wrote:
> repo, see
> Best regards,
> Kai
Ed Merks
Re: Slicer mode for target platform? [message #1699641 is a reply to message #1699588] Thu, 25 June 2015 13:03 Go to previous messageGo to next message
Done: https://bugs.eclipse.org/bugs/show_bug.cgi?id=470992
Re: Slicer mode for target platform? [message #1699733 is a reply to message #1699588] Fri, 26 June 2015 08:56 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Guys,
Actually this annotation detail is already available:
<base:StringToStringMapEntry
xmi:version="2.0"
xmlns:base="http://www.eclipse.org/oomph/base/1.0"
key="includeMode">
<value>slicer</value>
</base:StringToStringMapEntry>
You can copy this XML snippet and paste it directly on the TargetDefinitionGenerator annotation ;-)
Cheers
/Eike
http://www.esc-net.de
Am 25.06.2015 um 11:18 schrieb Ed Merks:
> Kai,
> No, there's nothing for that yet, but certainly we could add a bit more annotation magic to specify that. Please open
>> Hi,
>> Best regards,
>> Kai
Re: Slicer mode for target platform? [message #1699756 is a reply to message #1699733] Fri, 26 June 2015 11:23 Go to previous message
Hi Eike,
Do you mean like this?
      <targlet
          name="openHAB 2 Target Platform"
          activeRepositoryList="${eclipse.target.platform}">
        <annotation
            source="http:/www.eclipse.org/oomph/targlets/TargetDefinitionGenerator">
				xmi:version="2.0"
				key="includeMode">
          	<detail
              	key="location">
            	<value>${git.clone.openhab2.location/targetplatform/openhab.target}</value>
          	</detail>
Not sure if this will work, since I cannot even get this far. Note that my request was not (only) about the generated target file, but mainly about the TargletTask itself. This obviously still fails, if the target platform dependencies cannot be fully resolved:
  ERROR: org.eclipse.equinox.p2.director code=0 Software being installed: artificial_root 1.0.0.v1435317671966
  ERROR: org.eclipse.equinox.p2.director code=0 Missing requirement: Jetty-OSGi-Jasper Integration 9.2.10.v20150310 (org.eclipse.jetty.osgi.boot.jsp 9.2.10.v20150310) requires 'package javax.el [3.0.0,3.1.0)' but it could not be found
  ERROR: org.eclipse.equinox.p2.director code=1 Cannot satisfy dependency:
    ERROR: org.eclipse.equinox.p2.director code=0 From: artificial_root 1.0.0.v1435317671966
    ERROR: org.eclipse.equinox.p2.director code=0 To: org.eclipse.jetty.bundles.f.feature.group [9.2.10,9.3.0]
Kai
Previous Topic:Creating a custom installer for a project outside the Project Catalogue
Next Topic:Using the "Setup Project Model" wizard--with newbie mistakes
Current Time: Sun Jan 19 18:02:45 GMT 2025
Powered by FUDForum. Page generated in 0.04099 seconds
