Home » Eclipse Projects » Sirius » Keybinding conflict Sirius & XText(CTRL+O, CTRL+L shortcut conflict btw Sirius & XText)
Keybinding conflict Sirius & XText [message #1699260] |
Tue, 23 June 2015 06:40 |
Huy Le Messages: 18 Registered: November 2014 |
How can we deal with the following keys conflict?
!MESSAGE A conflict occurred for CTRL+O:
Binding(CTRL+O,
ParameterizedCommand(Command(org.eclipse.sirius.diagram.ui.command.show.outline,Quick outline,
Category(org.eclipse.core.commands.categories.autogenerated,Uncategorized,Commands that were either auto-generated or have no category,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@560e50d4,
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.sirius.diagram.ui.diagramContext,,,system)
Binding(CTRL+O,
ParameterizedCommand(Command(org.eclipse.xtext.ui.editor.outline.QuickOutline,Quick Outline,
Open the quick outline.,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@7e8cb9a7,
,,true),null),
org.eclipse.xtext.ui.XtextEditorScope,,,system)
!SUBENTRY 1 org.eclipse.jface 2 0 2015-06-23 13:22:49.833
!MESSAGE A conflict occurred for CTRL+L:
Binding(CTRL+L,
ParameterizedCommand(Command(org.eclipse.sirius.diagram.ui.command.hideLabel,Hide label,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@2005b8a9,
,,true),null),
Binding(CTRL+L,
ParameterizedCommand(Command(org.eclipse.ui.edit.text.goto.line,Go to Line,
Go to a specified line of text,
Category(org.eclipse.ui.category.navigate,Navigate,null,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@191dd1f5,
,,true),null),
org.eclipse.ui.textEditorScope,,,system)
Huy
Re: Keybinding conflict Sirius & XText [message #1699270 is a reply to message #1699260] |
Tue, 23 June 2015 08:04 |
Hi Huy,
Can you tell me how you end up having these exceptions? You have a
Sirius Editor and an XText resource? I have not experience this key
binding overlap so far.
We can try to be more specific in the key binding enablement but it may
not be enough in your case. However, this key binding should be
accessible for user redefinition in the menu
"Windows>Preference>General>Keys". Can you create a bugzilla issue for this?
Steve
Le 23/06/2015 08:40, Huy Le a écrit :
> Binding(CTRL+O,
> mailto:org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@560e50d4,
> ,,true),null),
> Binding(CTRL+O,
> mailto:org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@7e8cb9a7,
> ,,true),null),
> Binding(CTRL+L,
> mailto:org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@2005b8a9,
> ,,true),null),
> Binding(CTRL+L,
> to Line,
> mailto:org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@191dd1f5,
> ,,true),null),
> Huy
Steve Monnier - Obeo
Need professional services for Sirius?
Steve Monnier - Obeo Canada
Current Time: Fri Apr 19 03:09:16 GMT 2024
Powered by FUDForum. Page generated in 0.02133 seconds
