Home » Eclipse Projects » Sirius » How to call a Java service
How to call a Java service [message #1699234] Mon, 22 June 2015 19:43 Go to next message
qwer qwer is currently offline qwer qwerFriend
Hi everyone,
a couple of days I'm trying to call a Java Service from my viewpoint but I can't make it work. I need a service with a method which creates a label for a component of my diagram.
I have a single viewpoint specification project with my metamodel, model, .odesign and in src/mypackage I defined the Java service with a public constructor with no arguments and a public method which takes a paramter from type EObject and returns an EObject. I tried to reference the service through Java Extension (with path: MyProject/src/mypackage/Service.java) but it doesn't seem to be working. The service could not be found and I am not able to call the method (through Service:myMethod or [myObject.myMethod()/]).
Could you please tell me, what I'm doing wrong and what is the right way to call a Java Service. Sirius is something new for me, I'm a beginner.
Thank you in advance! Smile
Re: How to call a Java service [message #1699339 is a reply to message #1699234] Tue, 23 June 2015 13:33 Go to previous messageGo to next message
Maxime Porhel is currently offline Maxime PorhelFriend
Hi "qwer qwer"
Le 23/06/2015 15:08, qwer qwer a écrit :
> Hi everyone,
You will find information about Java services in [1], note that you have
to use the "fully qualified Java name" of your service class.
You should try: mypackage.Service
"Service:" is not supported, the prefix of the service interpreter is
"service:".
> Thank you in advance! :)
Maxime - Obeo
Need professional services for Sirius?
[1]
https://www.eclipse.org/sirius/doc/specifier/general/Writing_Queries.html#service_methods
Maxime Porhel - Obeo
Re: How to call a Java service [message #1699361 is a reply to message #1699339] Tue, 23 June 2015 15:32 Go to previous message
Thank you, Maxime but it doesn't work again. I suppose, the different parts have to be deployed on different eclipse instances but I don't know which parts and in what kind of projects. I found this topic here and in one of the posts there are two exmples attached but the links don't work. https://www.eclipse.org/forums/index.php/t/632359/
Do you have any exmaples with Java services?
Previous Topic:Get model file location of current editing diagram
Next Topic:How to implement Label Propagation Mechanism with the Java Extension or Java Service?
Current Time: Tue Apr 16 22:33:12 GMT 2024
Powered by FUDForum. Page generated in 1.69710 seconds
