Re: [CDO] Package exception [message #1699185 is a reply to message #1699064] |
Mon, 22 June 2015 11:42 |
Stephane fournier Messages: 340 Registered: July 2009 |
Hi Eike,
I'm a not sure it is a new effect ?
I'm still using CDO version 4.3.1 shipped with Luna Modeling SR1 distribution.
The exception :
[ERROR] Generated packages locally not available: CDOPackageUnit[id=http://bit/1.0.0, state=PROXY, type=UNKNOWN, originalType=NATIVE, timeStamp=2015-06-22 13:37:15.564]
[ERROR] Invalid signalID 0
org.eclipse.emf.cdo.common.util.CDOException: Generated packages locally not available: CDOPackageUnit[id=http://bit/1.0.0, state=PROXY, type=UNKNOWN, originalType=NATIVE, timeStamp=2015-06-22 13:37:15.564]
at org.eclipse.emf.internal.cdo.session.CDOSessionImpl.loadPackages(CDOSessionImpl.java:566)
at org.eclipse.emf.cdo.internal.common.model.CDOPackageUnitImpl.load(CDOPackageUnitImpl.java:239)
at org.eclipse.emf.cdo.internal.common.model.CDOPackageUnitImpl.load(CDOPackageUnitImpl.java:228)
at org.eclipse.emf.cdo.internal.common.model.CDOPackageInfoImpl.getEPackage(CDOPackageInfoImpl.java:116)
at org.eclipse.emf.cdo.internal.common.model.CDOPackageInfoImpl.getEPackage(CDOPackageInfoImpl.java:109)
at org.eclipse.emf.ecore.impl.EPackageRegistryImpl.getEPackage(EPackageRegistryImpl.java:127)
at org.eclipse.emf.cdo.common.model.CDOClassifierRef.resolve(CDOClassifierRef.java:113)
at org.eclipse.emf.cdo.spi.common.protocol.CDODataInputImpl.readCDOClassifierRefAndResolve(CDODataInputImpl.java:170)
at org.eclipse.emf.cdo.spi.common.revision.BaseCDORevision.readSystemValues(BaseCDORevision.java:210)
at org.eclipse.emf.cdo.spi.common.revision.BaseCDORevision.read(BaseCDORevision.java:163)
at org.eclipse.emf.cdo.spi.common.protocol.CDODataInputImpl.readCDORevision(CDODataInputImpl.java:427)
at org.eclipse.emf.cdo.spi.common.protocol.CDODataInputImpl.readCDORevision(CDODataInputImpl.java:418)
at org.eclipse.emf.cdo.spi.common.protocol.CDODataInputImpl.readCDOChangeSetData(CDODataInputImpl.java:212)
at org.eclipse.emf.cdo.spi.common.protocol.CDODataInputImpl.readCDOCommitData(CDODataInputImpl.java:264)
at org.eclipse.emf.cdo.spi.common.protocol.CDODataInputImpl.readCDOCommitInfo(CDODataInputImpl.java:279)
at org.eclipse.emf.cdo.common.protocol.CDOProtocol$CommitNotificationInfo.<init>(CDOProtocol.java:75)
at org.eclipse.emf.cdo.internal.net4j.protocol.CommitNotificationIndication.indicating(CommitNotificationIndication.java:36)
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientIndication.indicating(CDOClientIndication.java:74)
at org.eclipse.net4j.signal.Indication.doExtendedInput(Indication.java:57)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:331)
at org.eclipse.net4j.signal.Indication.execute(Indication.java:51)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:256)
at org.eclipse.net4j.signal.Signal.run(Signal.java:149)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
java.lang.IllegalArgumentException: Invalid signalID 0
at org.eclipse.net4j.signal.SignalProtocol.provideSignalReactor(SignalProtocol.java:343)
at org.eclipse.net4j.signal.SignalProtocol.handleBuffer(SignalProtocol.java:211)
at org.eclipse.spi.net4j.Channel$ReceiverWork.run(Channel.java:366)
at org.eclipse.net4j.util.concurrent.QueueRunner.work(QueueRunner.java:26)
at org.eclipse.net4j.util.concurrent.QueueRunner.work(QueueRunner.java:1)
at org.eclipse.net4j.util.concurrent.QueueWorker.doWork(QueueWorker.java:78)
at org.eclipse.net4j.util.concurrent.QueueWorker.work(QueueWorker.java:70)
at org.eclipse.net4j.util.concurrent.Worker$WorkerThread.run(Worker.java:209)
Eike Stepper wrote on Sat, 20 June 2015 01:21Hi Stephane,
Please show the the stack trace and tell us the version of CDO you're using? Is that a new effect?
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Package exception [message #1700086 is a reply to message #1699185] |
Tue, 30 June 2015 05:29 |
Am 22.06.2015 um 13:42 schrieb Stephane Fournier:
> Hi Eike,
> I'm a not sure it is a new effect ? I'm still using CDO version 4.3.1 shipped with Luna Modeling SR1 distribution.
If this problem is new (for you) and you didn't update the CDO version, then you may have changed something in your
application. Or you execute new scenarios now. I'm trying to understand why that happens NOW.
> The exception :
Is this package empty? Or doesn't it have at least one concrete EClass?
You can set CDOSession.Options.setGeneratedPackageEmulationEnabled(true) to allow the use of dynamic packages even in
cases where the original package was generated.
What is this?
Are there other stack traces in the log (related to protocol version mismatches or so)?
What protocols are you using?
Cheers
/Eike
> at
>> Hi Stephane,
>> Cheers
>> /Eike
>> http://thegordian.blogspot.com
>> http://twitter.com/eikestepper
Cheers
/Eike
Re: [CDO] Package exception [message #1700212 is a reply to message #1700086] |
Tue, 30 June 2015 20:02 |
Eike Stepper wrote on Tue, 30 June 2015 01:29Am 22.06.2015 um 13:42 schrieb Stephane Fournier:
> Hi Eike,
> The exception :
I have multiple applications (each one has its own JVM) connected to same repository ( a mem store one).
I have 3 CDO resources in the repository.
One of the resource is using an EMF model that the other 2 resources do not know. No link between the 2 first resources and the 3rd one.
Thus, one application is connected to all resources and knows every EMF packages
==> no issue.
But another application named "AppFooBar" (for instance) has only to deal with 2 first CDO resources, no need to load the 3rd one.
==> The EMF plug-in for the EMF model that is not used by AppFooBar is not deployed at all in this Equinox app.
This is why I get this exception, if I deploy the bundle in the AppFooBar app without using it, I do not have the error. But deploying a useless EMF model bundle is a bit strange in a component-based application approach
The CDO server is notifying my AppFooBar (as CDO client) about the 3rd resource creation with a content that this application is not supposed to deal with.
I never try to load this 3rd resource in the transaction of the AppFooBar app.
Is this use case managed by CDO ?
Ok I will test this setting.
What is this?
I'am using TCP/IP protocol between clients and the MemStore CDO server. All CDO & EMF bundles are the ones from Luna Modeling SR1 (4.3.1)
Thanks for your help and your time to help me.
Cheers
/Eike
> at
>> Hi Stephane,
>> Cheers
>> /Eike
FUDForum. Page generated in 0.03079 seconds
