Re: Headless SWTBot tests fail on Windows [message #1699221 is a reply to message #1699000] |
Mon, 22 June 2015 16:47 |
On 19/06/2015 14:07, Donat Csikos wrote:
> I'm trying to add a few SWTBot UI tests to the Buildship project (Gradle
> integration for Eclipse) and I encountered a strange issue. When the
> tests are running locally they pass both on Linux and on Windows. But,
> when the same tests run on the CI server, they pass on Linux but fail on
> Windows.
> When analysing the error log, it says, widget not found. The screenshot
> created by the tests is an 1024x768 blanc jpeg image. An example for the
> failing build is available here:
> https://builds.gradle.org/viewLog.html?buildId=346679&tab=buildResultsDiv&buildTypeId=Tooling_Master_Commit_Windows_Eclipse37Build
> (credentials: guest/guest)
> The test execution is done by Gradle, which under the hood only executes
> the following console command: Command:
> /Library/Java/JavaVirtualMachines/jdk1.8.0_20.jdk/Contents/Home/bin/java
> -Declipse.p2.data.area=@config.dir/p2 -Declipse.pde.launch=true
> -Dosgi.requiredJavaVersion=1.7 -XX:MaxPermSize=256m -XstartOnFirstThread
> -Xms40m -Xmx1024m -Dfile.encoding=UTF-8 -Duser.country=US
> -Duser.language=en -Duser.variant -cp
> /Users/donat/Development/oomph/buildship-master/git/buildship/org.eclipse.buildship.ui.test/build/eclipseTest/eclipse/plugins/org.eclipse.equinox.launcher_1.3.100.v20150511-1540.jar
> org.eclipse.equinox.launcher.Main -os macosx -ws cocoa -arch x86_64
> -consoleLog -debug
> /Users/donat/Development/oomph/buildship-master/git/buildship/org.eclipse.buildship.core/.options
> -version 4 -port 61227 -testLoaderClass
> org.eclipse.jdt.internal.junit4.runner.JUnit4TestLoader
> -loaderpluginname org.eclipse.jdt.junit4.runtime -classNames
> org.eclipse.buildship.ui.wizard.project.ProjectCreationWizardUiTest
> -application org.eclipse.swtbot.eclipse.core.swtbottestapplication
> -product org.eclipse.platform.ide -data
> -configuration
> /Users/donat/Development/oomph/buildship-master/git/buildship/org.eclipse.buildship.ui.test/build/eclipseTest/eclipse/configuration
> -testpluginname org.eclipse.buildship.ui
> Any help is greatly appreciated!
did you check the hints for windows reported here:
https://wiki.eclipse.org/SWTBot/Automate_test_execution
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
TDD Book: https://leanpub.com/tdd-buildautomation-ci
Xtext Book: https://www.packtpub.com/application-development/implementing-domain-specific-languages-xtext-and-xtend-second-edition
FUDForum. Page generated in 0.02735 seconds
