Home » Eclipse Projects » Sirius » Conditional Style using Enumeration Type
Conditional Style using Enumeration Type [message #1698793] Wed, 17 June 2015 17:49 Go to next message
I have a question on a conditional style.
Like the following image, "Softgoal" has a "label:SatisficingLabelType" which is an Enum type containing "Undecided", "Satisficed", and etc. I want to show node style depending on the label value of a Softgoal node. In a conditional style, how shoud I write a query depending on the value of the label? I tried to use [self.label.toString.matches('Satisficed')=true/], but it does not work.
Could someone help me?
Thank you so much.
Best Regards,
Eunjung Park
Re: Conditional Style using Enumeration Type [message #1698798 is a reply to message #1698793] Wed, 17 June 2015 18:03 Go to previous messageGo to next message
I could figure out.
I should have used [self.label.toString().matches('Satisficed')=true/].
Thanks.
Eunjung Park
Re: Conditional Style using Enumeration Type [message #1698820 is a reply to message #1698798] Thu, 18 June 2015 03:35 Go to previous messageGo to next message
Le 18/06/2015 00:03, eunjung park a écrit :
> I could figure out.
> Thanks.
> Eunjung Park
As explained on a previous post [1] and on the Acceleo wiki [2], you can
test an EEnum typed attribute as shown in the following Acceleo expression:
[self.label = SatisficingLabelType::Satisficed'/]
:: is the qualifier separator in Acceleo MTL.
Maxime - Obeo
Need professional services for Sirius?
[1]
https://www.eclipse.org/forums/index.php/m/1695955/?srch=enumeration#msg_1695955
[2]
https://wiki.eclipse.org/Acceleo/FAQ#How_do_I_compare_data_to_an_enumeration_value.3F
Re: Conditional Style using Enumeration Type [message #1699071 is a reply to message #1698820] Sat, 20 June 2015 04:56 Go to previous message
Hi Maxime.
Thank you so much.
I can use right expression.
Thanks again.
Best Regards,
Eunjung Park
Previous Topic:Is it possible to show edges in a container?
Next Topic:Composite Layout
Current Time: Sat Jun 21 04:59:55 EDT 2025
Powered by FUDForum. Page generated in 0.05732 seconds
