Home » Modeling » Papyrus » "Refine" stereotype [SysML]
"Refine" stereotype [SysML] [message #1698250] Fri, 12 June 2015 13:44 Go to next message
Adrian Ww is currently offline Adrian WwFriend
I'm searching for "refine" stereotype between a use case and a requirement in a SysML project.
I tried to customize the palette but when I add the "refine", Eclipse doesn't add it to the nodes.
Thank you for your help.
Re: "Refine" stereotype [SysML] [message #1698261 is a reply to message #1698250] Fri, 12 June 2015 15:43 Go to previous messageGo to next message
Christian Damus is currently offline Christian DamusFriend
The Refine stereotype is defined in the UML Standard Profile. You will
first have to apply that profile to your SysML model before you can
apply this stereotype.
HTH,
Christian
On 2015-06-12 13:44:43 +0000, Adrian Ww said:
Re: "Refine" stereotype [SysML] [message #1698364 is a reply to message #1698261] Mon, 15 June 2015 06:50 Go to previous messageGo to next message
Thank you for your answer.
But how can I apply a UML standard profile to my SysML model ?
Re: "Refine" stereotype [SysML] [message #1698368 is a reply to message #1698364] Mon, 15 June 2015 07:11 Go to previous messageGo to next message
Thomas Wiman is currently offline Thomas WimanFriend
Member
To apply the standard UML profile to a SysML-model
1) Bring up the profile tab in the Properties View for your SysML model.
2) Select the "Apply Registered Profile" button in the upper right of the view
3) Select the "Standard" profile in the dialog, and apply the profile in the next dialog page.
/Thomas
Thomas Wiman
MetaModelAgent Product Manager
Re: "Refine" stereotype [SysML] [message #1698375 is a reply to message #1698368] Mon, 15 June 2015 08:08 Go to previous message
Thank you so much it works now !
Previous Topic:Match SpecializationType by stereotype proroperty
Next Topic:How to import uml models programmatically in the mode "User Model"
Current Time: Mon Jan 18 15:00:13 GMT 2021
Powered by FUDForum. Page generated in 0.01530 seconds
