Re: [buckminster-dev] help run mwe2 workflows through headless build [message #1697917 is a reply to message #1697910] |
Tue, 09 June 2015 15:13 |
On 09/06/2015 16:36, sivanarayana ganesh wrote:
> I'm trying to build mwe2 workflows through an ant task. I'm running into
> following issues.
> Here is my ant task:
> <path id="Plug-in Dependencies.libraryclasspath">
> <pathelement location="../com.grammer.ovn.de
> <http://com.grammer.ovn.de>"/>
> <pathelement location="../com.grammer.ovn.rules"/>
> </path>
> <path id="mydsl.classpath">
> <pathelement location="bin"/>
> <path refid="Plug-in Dependencies.libraryclasspath"/>
> </path>
> <target name="gen">
> <java classname="org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher"
> classpathref="mydsl.classpath" fork="true">
> <arg
> value="../com.grammar.ovn.de/src/com/grammar/ovn/GenerateDataElements.mwe2
> <http://com.grammar.ovn.de/src/com/grammar/ovn/GenerateDataElements.mwe2>"
> <arg
> value="../com.grammar.ovn.rules/src/com/grammar/ovn/GenerateRules.mwe2" />
> </java>
> </target>
> ERROR:
> [java] Error: Could not find or load main class
> [java] Java Result: 1
> Any help is appreciated.
> Thank you.
> -Siva.
I think you should use the buckminster forum eclipse.tools.buckminster
for user related questions (I guess this forum is for developer related
questions :)
Anyway, If you run such ant task from buckminster, then the mwe2
launcher has to be installed in buckminster itself; so, when installing
buckminster, you should also install the feature
org.eclipse.emf.mwe2.launcher.feature.group which can be found in this
update site
http://download.eclipse.org/modeling/emft/mwe/updates/releases/2.7.1/ or
in the Xtext composite update site.
Hope this helps
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
TDD Book: https://leanpub.com/tdd-buildautomation-ci
Xtext Book: https://www.packtpub.com/application-development/implementing-domain-specific-languages-xtext-and-xtend-second-edition
Re: [buckminster-dev] help run mwe2 workflows through headless build [message #1697950 is a reply to message #1697917] |
Tue, 09 June 2015 19:28 |
Siva Gaddam Messages: 22 Registered: June 2015 |
<div dir="ltr">Oops. Sorry for that. Thanks a lot for the help.</div><div class="gmail_extra"><br><div class="gmail_quote">On Tue, Jun 9, 2015 at 8:13 AM, Lorenzo Bettini <span dir="ltr"><<a href="mailto:bettini@xxxxxxxx.it" target="_blank">bettini@xxxxxxxx.it</a>></span> wrote:<br><blockquote class="gmail_quote" style="margin:0 0 0 .8ex;border-left:1px #ccc solid;padding-left:1ex"><span class="">On 09/06/2015 16:36, sivanarayana ganesh wrote:<br>
> Hi,<br>
><br>
> I'm trying to build mwe2 workflows through an ant task. I'm running into<br>
> following issues.<br>
><br>
> Here is my ant task:<br>
><br>
> <path id="Plug-in Dependencies.libraryclasspath"><br>
> <pathelement location="../<a href="http://com.grammer.ovn.de" target="_blank">com.grammer.ovn.de</a><br>
</span>> <<a href="http://com.grammer.ovn.de" target="_blank">http://com.grammer.ovn.de</a>>"/><br>
<span class="">> <pathelement location="../com.grammer.ovn.rules"/><br>
> </path><br>
><br>
> <path id="mydsl.classpath"><br>
> <pathelement location="bin"/><br>
> <path refid="Plug-in Dependencies.libraryclasspath"/><br>
> </path><br>
><br>
> <target name="gen"><br>
> <java classname="org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher"<br>
> classpathref="mydsl.classpath" fork="true"><br>
> <arg<br>
> value="../<a href="http://com.grammar.ovn.de/src/com/grammar/ovn/GenerateDataElements.mwe2" target="_blank">com.grammar.ovn.de/src/com/grammar/ovn/GenerateDataElements.mwe2</a><br>
</span>> <<a href="http://com.grammar.ovn.de/src/com/grammar/ovn/GenerateDataElements.mwe2" target="_blank">http://com.grammar.ovn.de/src/com/grammar/ovn/GenerateDataElements.mwe2</a>>"<br>
<span class="">> /><br>
> <arg<br>
> value="../com.grammar.ovn.rules/src/com/grammar/ovn/GenerateRules.mwe2" /><br>
> </java><br>
> </target><br>
><br>
> ERROR:<br>
> [java] Error: Could not find or load main class<br>
> org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher<br>
> [java] Java Result: 1<br>
><br>
> Any help is appreciated.<br>
><br>
> Thank you.<br>
><br>
> -Siva.<br>
<br>
</span>Hi<br>
<br>
I think you should use the buckminster forum eclipse.tools.buckminster<br>
for user related questions (I guess this forum is for developer related<br>
questions :)<br>
<br>
Anyway, If you run such ant task from buckminster, then the mwe2<br>
launcher has to be installed in buckminster itself; so, when installing<br>
buckminster, you should also install the feature<br>
org.eclipse.emf.mwe2.launcher.feature.group which can be found in this<br>
update site<br>
<a href="http://download.eclipse.org/modeling/emft/mwe/updates/releases/2..7.1/" target="_blank">http://download.eclipse.org/modeling/emft/mwe/updates/releases/2.7.1/</a> or<br>
in the Xtext composite update site.<br>
<br>
Hope this helps<br>
<span class="HOEnZb"><font color="#888888"> Lorenzo<br>
<br>
--<br>
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino<br>
HOME: <a href="http://www.lorenzobettini.it" target="_blank">http://www..lorenzobettini.it</a><br>
Xtext Book:<br>
<a href="http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book" target="_blank">http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book</a><br>
<br>
_______________________________________________<br>
buckminster-dev mailing list<br>
<a href="mailto:buckminster-dev@xxxxxxxx">buckminster-dev@xxxxxxxx</a><br>
To change your delivery options, retrieve your password, or unsubscribe from this list, visit<br>
<a href="https://dev.eclipse.org/mailman/listinfo/buckminster-dev" target="_blank">https://dev.eclipse.org/mailman/listinfo/buckminster-dev</a><br>
</font></span></blockquote></div><br></div>
FUDForum. Page generated in 0.02886 seconds
