Re: Model Spy not working [message #1702020 is a reply to message #1697777] |
Fri, 17 July 2015 14:16 |
Paul Roubekas Messages: 207 Registered: March 2012 Location: Chattanooga, TN USA |
Windows 7 SP1
MARS 4.5.0
Build id: 20150621-1200
Eclipse 4 - Model Spy (Incubation) 0.1.0.v20150714-0417 org.eclipse.e4.tools.model.spy.feature.feature.group Eclipse.org
One month later I am was reading a different article (http://eclipsesource.com/blogs/2012/05/10/eclipse-4-final-sprint-part-1-the-e4-application-model/) by Jonas Helming but this issue is still the same. The Shift+Alt+F9 does nothing. I checked the hot key mappings and found the Shift+Alt+F9 combo listed as follows.
Name: Open a spy ()
Description: Open a spy in the E4 spy window
Binding: Open a spy in the E4 spy window
When: In Dialogs and Windows
Conflicts: (none listed)
Question 1) Being new to the Spy project, is this the correct forum? My search on the forums with the strings "e4ap, Eclipse4, Model Spy" only got this thread as a hit.
Question 2) Is there a bug report on this?
Question 3) Is the statementQuote: "You should not include the model spy in your exported application as it is only a test and debug tool. It is not intended to be used by end users." correct?
Oxygen 3a
Windows 10
[Updated on: Fri, 17 July 2015 14:16] Report message to a moderator
FUDForum. Page generated in 0.04264 seconds
