Re: [buckminster-dev] download buckminster headless issue [message #1697574 is a reply to message #1697561] |
Fri, 05 June 2015 06:15 |
Hi Siva,
The second option should work provided that the different servers are on the same architecture, but ensure that you
install a movable product (i.e. use the director option -roaming) and make sure that the installation directory (the
argument to -destination) is an absolute path.
It might be good to initialize the product after unzipping it on a server, i.e.
buckminster -initialize
HTH,
- thomas
On 2015-06-05 01:39, sivanarayana ganesh wrote:
> Hello,
> I'm trying to configure jenkins to build dsl projects. Thus, i started off writing shell script to install director and
> buckminster commandlin product. Unfortunately, our server is behind firewall and they don't like to setup proxy on our
> servers. Here is what I'm doing.
> 1. Download the director
> 2. unzip and ran the following command to download buckminster headless
> ./director -r http://download.eclipse.org/tools/buckminster/headless-4.4/ -d ./buck -downloadOnly -p Buckminster
> ---> showing help.
> Anyone succeded in downloading the artifact? please share the command.
> if it's a bug with director, does it work if I do the following.
> 1. Use director to install buckminster
> 2. Zip buckminster and upload to our internal repo
> 3. Download the buckminster from our internal repo, unzip to some location build server through shell script which will
> run on jenkins server.
> 4. build the project with -Dbuckminster.home = <location from step 3>
> I really appreciate your help.
> Thanks.
> -Siva.
Re: [buckminster-dev] download buckminster headless issue [message #1697645 is a reply to message #1697574] |
Fri, 05 June 2015 14:52 |
Siva Gaddam Messages: 22 Registered: June 2015 |
<div dir="ltr">Hi Thomas,<div><br></div><div>Thank you very much.</div><div><br></div><div>-Siva.</div></div><div class="gmail_extra"><br><div class="gmail_quote">On Thu, Jun 4, 2015 at 11:15 PM, Thomas Hallgren <span dir="ltr"><<a href="mailto:thomas@xxxxxxxx" target="_blank">thomas@xxxxxxxx</a>></span> wrote:<br><blockquote class="gmail_quote" style="margin:0 0 0 .8ex;border-left:1px #ccc solid;padding-left:1ex">Hi Siva,<br>
<br>
The second option should work provided that the different servers are on the same architecture, but ensure that you install a movable product (i.e. use the director option -roaming) and make sure that the installation directory (the argument to -destination) is an absolute path.<br>
<br>
It might be good to initialize the product after unzipping it on a server, i.e.<br>
<br>
buckminster -initialize<br>
<br>
HTH,<br>
- thomas<div><div class="h5"><br>
<br>
On 2015-06-05 01:39, sivanarayana ganesh wrote:<br>
Hello,<br>
<br>
I'm trying to configure jenkins to build dsl projects. Thus, i started off writing shell script to install director and<br>
buckminster commandlin product. Unfortunately, our server is behind firewall and they don't like to setup proxy on our<br>
servers. Here is what I'm doing.<br>
<br>
1. Download the director<br>
2. unzip and ran the following command to download buckminster headless<br>
<br>
../director -r <a href="http://download.eclipse.org/tools/buckminster/headless-4.4/" target="_blank">http://download.eclipse.org/tools/buckminster/headless-4.4/</a> -d ./buck -downloadOnly -p Buckminster<br>
<br>
---> showing help.<br>
<br>
Anyone succeded in downloading the artifact? please share the command.<br>
<br>
if it's a bug with director, does it work if I do the following.<br>
<br>
1. Use director to install buckminster<br>
2. Zip buckminster and upload to our internal repo<br>
3. Download the buckminster from our internal repo, unzip to some location build server through shell script which will<br>
run on jenkins server.<br>
4. build the project with -Dbuckminster.home = <location from step 3><br>
<br>
I really appreciate your help.<br>
<br>
Thanks.<br>
<br>
-Siva.<br>
<br>
<br>
</blockquote>
<br></div></div>
_______________________________________________<br>
buckminster-dev mailing list<br>
<a href="mailto:buckminster-dev@xxxxxxxx" target="_blank">buckminster-dev@xxxxxxxx</a><br>
To change your delivery options, retrieve your password, or unsubscribe from this list, visit<br>
<a href="https://dev.eclipse.org/mailman/listinfo/buckminster-dev" target="_blank">https://dev.eclipse.org/mailman/listinfo/buckminster-dev</a><br>
</blockquote></div><br></div>
FUDForum. Page generated in 0.02968 seconds
