Home » Modeling » Graphiti » Graphiti Diagram(creating a graphiti diagram)
icon4.gif  Graphiti Diagram [message #1697548] Thu, 04 June 2015 19:16 Go to next message
Ayoub Makroz is currently offline Ayoub MakrozFriend
Hello Everyone,
I'm new with Eclipse, Creating ecore models and Creating graphiti diagrams of these ecore models.
Well the problem I'm facing right now, is that I don't know how to go from my domain model to a graphiti diagram.
I tried to redo the Hello World diagram (ht tp://www.ancitconsulting.com/tiki-download_file.php?fileId=35). But I can't create a graphiti diagram, all what I find is Graphiti examples diagrams.
In the tutorial they say that graphiti diagram is under Graphiti folder in the examples sections. I can't find this Graphiti folder
I'm using Luna 4.4.2, and I installed the latest version of graphiti ( http://download.eclipse.org/graphiti/updates/0.11.3).
Can you please help Sad
Re: Graphiti Diagram [message #1697654 is a reply to message #1697548] Fri, 05 June 2015 17:59 Go to previous messageGo to next message
Marek Jagielski is currently offline Marek JagielskiFriend
Member
Hi Ayoub,
For me, the best way to learn Graphiti was to analyse open source projects that use Graphiti. Particularly I have learnt Graphiti on two projects:
1. Activiti:
+ http://activiti.org/screenshots.html#images/screenshots/activiti-designer.png
+ https://github.com/Activiti/Activiti-Designer
2. BPMN modeler:
+ https://www.eclipse.org/bpmn2-modeler/
+ https://github.com/eclipse/bpmn2-modeler
Marek
Re: Graphiti Diagram [message #1697657 is a reply to message #1697654] Fri, 05 June 2015 18:32 Go to previous messageGo to next message
Thank you for your answer, but my question is (at least it seems) simple, how can I go from my domain model to a graphiti diagram.
Also I didn't know how to open the projects in eclipse ?? (I'm new with eclipse ^_^). And is there tutorial of the steps followed not just the code, because I already found a code for the chess example, but couldn't figure out how it works Razz
Re: Graphiti Diagram [message #1697859 is a reply to message #1697548] Tue, 09 June 2015 07:09 Go to previous messageGo to next message
Michael Wenz is currently offline Michael WenzFriend
Ayoub,
probably you have missed to define the required extensions in plugin.xml:
http://help.eclipse.org/kepler/index.jsp?topic=%2Forg.eclipse.graphiti.doc%2Fresources%2Fdocu%2Fgfw%2Fdiagram.htm&cp=27_1_2
(section Register the Diagram Type Provider and Diagram Type).
You can use the File --> New --> Project --> Plug-In Project wizard to
create a new plugin project (needed for any kind of Eclipse extensions),
provide a project name like "test1" click next until you reach "Templates"
page, mark "Plug-in with a Graphiti Editor" and click Finish. That will
create a very basic project containing everything you need to start with a
new Graphiti diagram editor, see:
http://help.eclipse.org/kepler/index.jsp?topic=%2Forg.eclipse.graphiti.doc%2Fresources%2Fdocu%2Ftools%2FNewPluginWizard.html&cp=27_4_0
To get familiar with Graphiti, the Graphiti tutorial would be a good
starting point, not sure if you have gone through that:
http://help.eclipse.org/kepler/index.jsp?nav=%2F27_1
To get familiar with Eclipse plugin development in general, you should step
through one of the tutorials out there in the web, e.g. the one by Lars
Vogel:
http://www.vogella.com/tutorials/EclipsePlugIn/article.html
The creation wizard for new Graphiti test projects has moved to File -->
New --> Project --> Other --> Graphiti Example Project. When you have such a
project you can open the context menu on that project and choose New -->
Graphiti Example Diagram. When your diagram type is correctly registered it
will appear in the drop down box for the diagram type.
Hope that helps...
Michael
Re: Graphiti Diagram [message #1698335 is a reply to message #1697859] Sun, 14 June 2015 11:08 Go to previous messageGo to next message
Thanks Michael, that helped me a lot
Re: Graphiti Diagram [message #1783341 is a reply to message #1698335] Mon, 12 March 2018 08:56 Go to previous message
Yves LEDUC is currently offline Yves LEDUCFriend
Member
In my Graphiti project I have a similar problem.
I wish to replace:
- New -> Graphiti Example Diagram by MyCategory> MyDomain Diagram
- The New Diagram dialog, Select diagram type by code defining the diagram type MyDiagramType
Can you tell me how to do that.
Yves
Previous Topic:Create after drop from external viewer
Next Topic:Multi Level Diagram
Current Time: Tue Mar 31 02:50:32 GMT 2020
Powered by FUDForum. Page generated in 0.03394 seconds
